non si avvia
Goto page 1, 2, 3 ... 9, 10, 11  Next
chris79
PostPosted: Fri Aug 01, 2014 11:09 pm    Post subject: non si avvia Reply with quote
Ciao,
da qualche tempo ho la 924 ferma.
Premetto che ho controllato già praticamente tutto e il problema sembrava essere il distributore di carburante k-jetronic.
Ultimamente però l'ho sostituito con uno revisionato ma ho ancora lo stesso problema.
In pratica la benzina arriva al distributore costantemente, le pompe funzionano, inizialmente la benzina arriva agli iniettori e il motore resta acceso per qualche secondo. Dopo un po di tempo la benzina continua a arrivare al distributore però non esce più dai fori che portano agli iniettori (l'ho verificato allentando le viti sopra la testina) ?
Come mai? Ero sicuro dipendesse dal distributore.
PostPosted: Sat Aug 02, 2014 12:03 am    Post subject: Reply with quote
Courtesy of Google Translate...
Quote:
Hello,
For some time I have the 924 stops.
I state that I have already checked almost everything and the problem seemed to be the K-Jetronic fuel distributor.
Lately, however, I replaced it with a revised but I still have the same problem.
In practice, the gas reaches the distributor constantly running pumps, gasoline initially comes to the injectors and the engine stays on for a few seconds. After some time the gasoline continues to get to the distributor but no longer out of the holes that lead to the injectors (I've checked by loosening the screws on top of the head)?
How so? I was sure depended on the distributor.
chris79
PostPosted: Sat Aug 02, 2014 9:14 pm    Post subject: . Reply with quote
anyone have any ideas?
PostPosted: Sat Aug 02, 2014 10:15 pm    Post subject: Reply with quote
Was hoping someone else would jump in here too...
When the engine will run only for a short time, then die, usually this indicates that it is running from fuel provided by the cold start injector, not the fuel distributor. Of course this matches your observation, no fuel coming from fuel distributor.
Can you get it to run a bit if you hold down the accelerator?
The replacement distributor, is it a used part or new? You used the word revisionato - maybe the translation is not accurate for technical terms, could the mean a part which is used but rebuilt (refreshed, given new seals and cleaning)?
chris79
PostPosted: Sat Aug 02, 2014 10:41 pm    Post subject: . Reply with quote
no but initially I verified that the fuel came from its distributor, in fact loosening the screws you could see that the fuel pressure was fine, then after some time he is not out more. It 'very strange because at the gas station and probably get back all in the fuel tank.
PostPosted: Sun Aug 03, 2014 12:23 am    Post subject: Reply with quote
No... this is not a refreshed distributor?
Has the car been running until recently, or has it been parked for years?
It is very common that when one of these cars is parked for years that contamination (dirt, rust, etc) is in the fuel tank and is pumped into the fuel distributor, which prevents it from working properly.
If the car has been parked for a long time, we recommend not just to replace the fuel filter but also to drain the fuel tank (from the hose leading to the fuel pump) and check the quality of the fuel - see if there is rust or dirt. You can maybe do this without completely emptying the tank - though it will be messy - if you have just filled the tank. Just drain into a bucket or gas can.
It is a good sign that you did have some fuel coming out when you loosened the screws. We just have to understand why it does not continue.
chris79
PostPosted: Sun Aug 03, 2014 1:46 am    Post subject: Reply with quote
In fact, I do not understand because they do not continue to go out, because the entrance to the head gasoline arrives, I tried unscrewing the nut arrival, it seems to go all in return.
KDJones2000
PostPosted: Sun Aug 03, 2014 2:18 am    Post subject: Reply with quote
As Vaughn said, dirt and rust is probably clogging your fuel distributors.
Your pumps are working, so fuel is coming to the fuel distributor, then returning to the fuel tank via the bypass. Since maybe the fuel distributor plunger is clogged and stuck, no fuel is coming out of the injector ports.
Clean out your fuel tank, put a new fuel filter just before the fuel distributor, and make sure that your fuel distributor is cleaned out.
Put some new fuel in and see if that fixes your problems.
Good luck, Keith
1987 924S SPEC car
Team Toofah Racing
1988 944 Turbo S
PostPosted: Sun Aug 03, 2014 2:20 am    Post subject: Reply with quote
Well, there are very small holes (orifices) to measure the fuel; it is very easy for these to get plugged with debris.
If you remove one of the lines that goes to a fuel injector, when the fuel pump is running (but engine not turning) there should be just a little bit of fuel coming out. Just very slowly.
Another test: If you remove the injectors from the head and place into glass bottles (you must do this to all injectors at the same time), then (with fuel pump running) push up the air metering plate. All four injectors should spray fuel, and the spray should be a consistent, fine mist. There should be no streams coming out, just mist, at high pressure.
But you must remove all 4 injectors from the head before performing this test; if you do not, you will have fuel filling the cylinder like a puddle, and it will end up in the bottom of the engine and dilute the oil. My Turbo is actually in this state now, and I have to go change the oil now as a result...
ThomasJoseph315
Guest
PostPosted: Sun Aug 03, 2014 3:33 am    Post subject: Reply with quote
Fuel Dizzy Plunger stuck closed?
chris79
PostPosted: Sun Aug 03, 2014 8:52 am    Post subject: Reply with quote
before you take the test the injectors should I do so that it comes more fuel from the head, otherwise it is useless. I saw that little fuel coming out and very dirty. Now I have removed the head, I blew air in the head with a compressor and the streets seem free, I try to reinstall it and will update.
ps. 924RACR your 924 is beautiful, just like I would turn my 924
PostPosted: Sun Aug 03, 2014 9:41 pm    Post subject: Reply with quote
Cheers, thanks, and good luck!
chris79
PostPosted: Sun Aug 03, 2014 11:36 pm    Post subject: Reply with quote
I mounted the distributor but it does not work, the fuel does not come out even with good pressure. I think the problem is only the petrol station, probably still too long. I already tried to restore one, but my problem is to use the seal around the metal membrane. I've tried using both products in the picture, but after a short time the seal comes off and the distributor loses.
Now I've decided to open the distributor, you have tips on what to use as a garnish?
KDJones2000
PostPosted: Sun Aug 03, 2014 11:50 pm    Post subject: Reply with quote
i didn't use anything and it sealed just fine.
1987 924S SPEC car
Team Toofah Racing
1988 944 Turbo S
PostPosted: Sun Aug 03, 2014 11:59 pm    Post subject: Reply with quote
What he said - should be no sealant there.
Dan Beckett (Ideola) recently pointed me to some fuel distributor rebuild kits on eBay, with new o-rings as well; fortunately I didn't need them, so I of course didn't save the link... maybe someone else here has?
Edit - OK, found it myself...
http://www.ebay.com/usr/cis-jetronic?_trksid=p2047675.l2559
But I would first try cleaning everything you have with acetone (brake parts cleaner), then reassemble clean, maybe with a little gasoline on the rubber parts to help lubricate.
Page 1 of 11
