heater hose
MRPETE
PostPosted: Sat Aug 30, 2014 5:10 pm    Post subject: heater hose Reply with quote
Hi guys .It never ends.Just blew a heater hose 477 819 723 any ideas? no best idea where to get em?I found some on the net but someone has probably got the best solution,if you know what I mean. Thanks Pete
'77 924
"81 924
Lots o' Corvairs
ThomasJoseph315
Guest
PostPosted: Sun Aug 31, 2014 12:00 am    Post subject: Reply with quote
Pelican Parts has it.
http://tinyurl.com/noexprp
PostPosted: Sun Aug 31, 2014 12:12 am    Post subject: Reply with quote
Usually, special order type part numbers at Pelican mean, NLA.
PostPosted: Sun Aug 31, 2014 2:09 am    Post subject: Reply with quote
Probably best to call Sunset Porsche in Oregon and at least get a discount since Pelican will mark up the OEM parts.
Autohausaz is another decent source with reasonable prices.
If it available in the aftermarket you might also check RockAuto.com.
ThomasJoseph315
Guest
PostPosted: Sun Aug 31, 2014 4:12 am    Post subject: Reply with quote
Are they the same diameter on both ends?
MRPETE
PostPosted: Sun Aug 31, 2014 5:00 am    Post subject: Reply with quote
No one end is about an inch and the other approx1\2 9\16
'77 924
"81 924
Lots o' Corvairs
ThomasJoseph315
Guest
PostPosted: Sun Aug 31, 2014 8:20 am    Post subject: Reply with quote
Looked through about 100 hoses nothing comes close, found this for now,..
http://www.jimellisporscheparts.com/products/Porsche/1983/hose/3651332/477819723A.html
MRPETE
PostPosted: Wed Sep 03, 2014 6:23 pm    Post subject: Reply with quote
Thanks guys.for now I just capped them off.I am going to construct a steel or copper assembly for peanuts that will use two straight pieces of rad hose and four clamps,rather than be held for ransom in the middle of nowhere. Thanks again Pete
'77 924
"81 924
Lots o' Corvairs
