931 Pic Questions: Where does this go and what goes here?!
brealytrent
PostPosted: Mon Sep 08, 2014 10:55 am    Post subject: 931 Pic Questions: Where does this go and what goes here?! Reply with quote
Where does this go?
What goes here (The tube on the bottom of the one intake runner)?
I'm trying to piece the car back together, but I've hit a couple bumps, like these two things. The haynes manual I can't find anything, as well as the parts fiche.
1977 Porsche 924 - sold
1980 Porsche 931 - sold
1984 Porsche 928 'S2' Euro - sold
2016 Ford Fiesta ST - sold
2009 Porsche Cayman
View user's profile Send private message Yahoo Messenger MSN Messenger
jason c
PostPosted: Mon Sep 08, 2014 11:29 am    Post subject: Reply with quote
The 90° boot goes to the turbo POV. The other end to the intake.
PostPosted: Mon Sep 08, 2014 12:13 pm    Post subject: Reply with quote
PIA to install, you'll have to take out the air cleaner, probably the CIS; just unbolt it and bend it over, carefully, over the engine. Stuff rag in the turbo. Even with access, this is not a fun job.
brealytrent
PostPosted: Mon Sep 08, 2014 1:57 pm    Post subject: Reply with quote
Well, it's good to know where that one line goes. And don't worry, everything is pretty much removed from the car, just set it all back in to get a better idea of how it all goes back together!
Now, what goes on that nipple?
2009 Porsche Cayman
PostPosted: Mon Sep 08, 2014 2:25 pm    Post subject: Reply with quote
The piece in your hand. Timing belt has to come off, I think. . .tube bolts to the engine via a water pump bolt.
kcoyle
PostPosted: Fri Sep 12, 2014 9:08 am    Post subject: Reply with quote
yup, I believe that's a fun one.
PostPosted: Fri Sep 12, 2014 9:22 pm    Post subject: Reply with quote
Yeah, it may even end up being necessary to remove the water pump slightly to wedge it in there. Make sure those boots don't have cracks!!! Very annoying to have to replace after install.
In case it isn't clear, the straight piece of hose is on the intake end, the elbow attaches to the turbo.
PostPosted: Fri Sep 12, 2014 10:15 pm    Post subject: Reply with quote
Careful with the rubber bits, both of those pieces are NLA, and the upper one to the manifold typically is difficult to remove after 34 years. So, they can get butchered on removal; yours looks good from here though!
