Rough Running 924
roybert
PostPosted: Thu Oct 09, 2014 8:21 am    Post subject: Rough Running 924 Reply with quote
I have a 83 Porsche 924 2.0 that I cant seem to get running right. Its lumpy on idle and its not pulling very well. It rev's out but feels like its off, its definitely slower than my other 924's. When she warms up full at idle its almost like its timing is slightly off. I checked for vacuum leaks and it looks good.
Any ideas? I have a quick video of it below (although its hard to tell in the video)
http://youtu.be/rGvZe5f-SO0
PostPosted: Thu Oct 09, 2014 9:56 am    Post subject: Re: Rough Running 924 Reply with quote
Simply not possible to check visually under ANY circumstances. . .sorry.
Ian89C4
PostPosted: Fri Oct 10, 2014 12:37 am    Post subject: Reply with quote
I would try resetting all of your timing. It sounds like your ignition timing is off a little bit and your not burning all the AF mixture in that chambers. Make sure that you ignition timing is set so that the distributor rotor is pointing at the scribe mark on the distributor.
Check your plugs too, they may have gone south on you.
I would try that first so at least you can rule out timing issues, then go after the daunting task of figuring out vacuum leaks.
cheers
Ian Edgerly
North Carolina
Current:
1980 924 Euro ("Wahala")
roybert
PostPosted: Fri Oct 10, 2014 1:52 am    Post subject: Reply with quote
cheers
Cool I`ll put in a new set of plugs, I dont know when they were done last as I am the newest owner. Thanks for the help. I`ll update on my progress!
musicalannette
PostPosted: Sat Oct 11, 2014 2:21 am    Post subject: Reply with quote
could be timing or running lean, check your mixture isnt set for too much air
roybert
PostPosted: Wed Nov 05, 2014 11:52 pm    Post subject: Reply with quote
Just a follow up guys, turns out it was a gunked up fuel filter. Fuel pressure was down by about 50%. Replaced it for 40 euro and we are good to go! Thanks for the help!
Ian89C4
PostPosted: Fri Nov 07, 2014 12:50 am    Post subject: Reply with quote
Excellent!! Glad when its an easy fix.
Cheers
Ian Edgerly
North Carolina
Current:
roybert
PostPosted: Mon Nov 10, 2014 9:31 pm    Post subject: Reply with quote
Now onto replacing the steering rack Once that's done that's most of the major work done. I can do the minor stuff and the car should be good to go!
PostPosted: Tue Nov 11, 2014 11:42 am    Post subject: Reply with quote
YIKES!!
i hope that included labor..
80 Turbo - Slightly Modified
