heat shield metal
leadfoot
PostPosted: Sat Dec 13, 2014 6:19 pm    Post subject: heat shield metal Reply with quote
galvanized steel?
cheers
Stu
1981 ROW 924 Turbo -
carbon fiber GT mish mash
LS1 conversion in progress...
jason c
PostPosted: Sat Dec 13, 2014 6:57 pm    Post subject: Reply with quote
Which ones?
leadfoot
PostPosted: Sat Dec 13, 2014 7:46 pm    Post subject: Reply with quote
between the torque tube and exhaust near the firewall
PostPosted: Sat Dec 13, 2014 9:18 pm    Post subject: Reply with quote
When I needed a starter motor heat shield I just used 26ga galvanized air duct. It is good for pretty high temperatures, and you should have a slight air gap anyway. I also found an old NOMEX(?) soldering cloth I had and used pop rivets to fasten it to the shield..
Mike
PostPosted: Sat Dec 13, 2014 11:28 pm    Post subject: Reply with quote
I checked and the properties of galvanized are ok for 390 F indefinitely, at 480F(250C) the galvanize will start to pee(over extended time period)l, they did not include their TTT chart. At 750F the material properties will start to be affected. Mind that these are for continuous exposure to these temperatures.
Mike
PostPosted: Mon Dec 15, 2014 4:19 am    Post subject: Reply with quote
Choose the metal you want to work with and ceramic coat it?
jason c
PostPosted: Mon Dec 15, 2014 11:03 am    Post subject: Reply with quote
The 944s use yellow, silver & clear zinc plating. Cadmium, was likely how the 924s were plated. They have more of a gold color than yellow. The heat shields that look like a grey bare metal were probably a grey or clear cad. I have a heat shield in very good shape, it doesn't appear to be the standard "flake" Galvanizing.
What are you trying to do, replate a part or make one from scratch?
