poor performance
chris79
PostPosted: Fri Jan 09, 2015 5:04 pm    Post subject: poor performance Reply with quote
After so many jobs my engine work, though the performance is poor, comes around 140 km / h , then loses power, why ?
PostPosted: Fri Jan 09, 2015 5:42 pm    Post subject: Reply with quote
What do you mean looses power at 140? Does it loose a lot of power or it just does not pull that hard anymore? Is it a turbo or a NA?
Check AFR and timing first.
Check compression second.
If it revs at 140 but does not go, check clutch for wear.
chris79
PostPosted: Fri Jan 09, 2015 6:36 pm    Post subject: Reply with quote
It's aspirated 924 of '79 , after about 140 km/h there is no more power, I found a lot of fuel in the motor oil, but I think because I tested injection whit engine off and fuel pump active.
PostPosted: Fri Jan 09, 2015 6:45 pm    Post subject: Reply with quote
Then change the oil NOW, otherwise you damage the engine...running with too thin oil.
Check fuel mixture, get a lambda probe and set the mixture using that.
Also get a timing light and check if the ignition timing is set right.
While you do that, check that the engine timing is also right, rotate the crank until the signs match and check if the cam sign is also matched.
PostPosted: Sat Jan 10, 2015 2:41 am    Post subject: Reply with quote
Check fuel pump volume per FSM, check for vacuum leaks.
chris79
PostPosted: Sat Jan 10, 2015 7:36 am    Post subject: Reply with quote
Do you know amount of flow in one minute for each injector ?
PostPosted: Sat Jan 10, 2015 7:41 am    Post subject: Reply with quote
Should be in the Haynes manual. What color are the spark plugs?
chris79
PostPosted: Sat Jan 10, 2015 8:10 am    Post subject: Reply with quote
I haven't found in Haynes,
spark are white color
jason c
PostPosted: Sat Jan 10, 2015 8:52 am    Post subject: Reply with quote
There is no spec for amount, only that they be even or within a % of each other. The amount varies based on plunger position. Since plunger position varies per car, no spec is given for amount.
PostPosted: Sat Jan 10, 2015 3:51 pm    Post subject: Reply with quote
Not so. Fuel pump volume/min is specified in FSM.
chris79
PostPosted: Sat Jan 10, 2015 6:17 pm    Post subject: Reply with quote
what's FSM ?
I'm in Italy, I don't know.
PostPosted: Sat Jan 10, 2015 6:30 pm    Post subject: Reply with quote
chris79 wrote:
what's FSM ?
Factory Service Manual.
78 924 NA
5-lug
chris79
PostPosted: Sat Jan 10, 2015 6:35 pm    Post subject: Reply with quote
translated in units of measurement?
PostPosted: Sat Jan 10, 2015 6:48 pm    Post subject: Reply with quote
Fuel pump should supply >= 750 cc in 30 seconds (after fuel filter, before fuel distributor).
Fuel pump current draw should be <= 8.5 amps.
78 924 NA
5-lug
chris79
PostPosted: Sat Jan 10, 2015 7:06 pm    Post subject: Reply with quote
ok, but if possible I want to know flow of injectors, because the pump is new and I suppose flow is correct. I want to check if fuel distributor is ok
