baffled/gatef sumps!
Jamie_924
PostPosted: Mon Jan 19, 2015 4:41 am    Post subject: baffled/gatef sumps! Reply with quote
Hi,
Just looking for a bit of info into the oil feed on 924s on track.
Has anyone had problems with surge or starvation on track and baffled their sumps?[/list]
PostPosted: Mon Jan 19, 2015 5:34 am    Post subject: Reply with quote
I use a Ishikara Johnson crank scraper on my 2.5 that slows the flow of oil up the right side of the sump, and I have never had oil pressure problems. However, Lindsey Racing here in the US sells a kit that creates a trap door and improved pickup that is fairly inexpensive and is used by many people.
Jamie_924
PostPosted: Mon Jan 19, 2015 5:51 am    Post subject: Reply with quote
Thanks for the reply....appreciated, maybe I should have been clearer, mines a n/a 2.0
Before the mod did you find any problems or have you fitted the setup as a precaution??
PostPosted: Mon Jan 19, 2015 6:04 am    Post subject: Reply with quote
Scraper was very inexpensive, and I liked the increased engine efficiency and oiling efficiency it provides.
Sorry about the misunderstanding. . .I saw "924s" and assumed it was a 2.5.
PostPosted: Mon Jan 19, 2015 9:12 am    Post subject: Reply with quote
I use the IJ crank scraper and an AccuSump on my 2.0. On board data acquisition shows no pressure drops ever on track.
daniel
PostPosted: Mon Jan 19, 2015 1:26 pm    Post subject: Reply with quote
I use a IJ scraper for the benefit of cutting down oil mist in the engine (which robs hp). I had no oil pressure issues before or after installing the scraper.
Daniel
1989 944 Cabriolet
PostPosted: Mon Jan 19, 2015 4:13 pm    Post subject: Reply with quote
Will you be running slicks? Otherwise I wouldnt bother, I have been track driving the last 10 years with my na and turbo without any problems, though on R compound tyres like Michelin pilot sport cup, R888 etc...
Jamie_924
PostPosted: Mon Jan 19, 2015 11:33 pm    Post subject: Reply with quote
No worries rasta I did think twice when writing that!
Thanks for the comments guys, I will be using r888 tyres on track.
