Conti Timing Kit
PostPosted: Sat Apr 25, 2015 1:18 am    Post subject: Conti Timing Kit Reply with quote
Did a belt service on Shaggy last night, and wanted to give some feedback on the Continental timing belt kit. The punch line: I loved it. It was only $18, and included a very nice tensioner (I've had trouble with noisy/crappy tensioners in the past).
Two thumbs up!
Part #TB017K1.
pcelenta
PostPosted: Sat Apr 25, 2015 2:04 am    Post subject: Reply with quote
where did you buy it from?
also, does it require a changing of the tensioner bolt to a shorter or longer one?
PostPosted: Sat Apr 25, 2015 2:26 am    Post subject: Reply with quote
Got it from WorldPac, but fcpeuro seems to have a good price on it. Tensioner is same design, just better made.
As for the bolt, it should be replaced if original anyway!
PostPosted: Sat Apr 25, 2015 3:18 am    Post subject: Reply with quote
First positive of a Conti kit I've seen. I had a poor experience of one recently. The belt was correct in tooth number but was 1/2 tooth longer than the one I took off and the OEM Dayco I replaced it with. I stick with Dayco from Porsche now.
Some UK guys generally appear to approve the Gates kit.
pcelenta
PostPosted: Sat Apr 25, 2015 5:33 am    Post subject: Reply with quote
I see a couple of ebay sellers just selling the dayco tensioner with a new stud and nut. it was my understanding the you had change the stud with a shorter or longer one (don't remember) with the new style tensioner.
PostPosted: Sat Apr 25, 2015 7:03 am    Post subject: Reply with quote
Stud? Mine's a bolt. . .
pcelenta
PostPosted: Sat Apr 25, 2015 9:49 am    Post subject: Reply with quote
http://www.ebay.com/itm/131390149231?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT#ht_1241wt_1312
this is the one with the stud
PostPosted: Sat Apr 25, 2015 4:18 pm    Post subject: Reply with quote
I always use Conti. The best kit you can get.
daniel
PostPosted: Mon Apr 27, 2015 9:38 am    Post subject: Reply with quote
I use Conti in all of my cars, never had a problem
1989 944 Cabriolet
