RobertN
Joined: 19 Apr 2015 Posts: 142 Location: Lisburn Co Antrim
Posted: Sat May 09, 2015 3:20 am Post subject: Rear brake adjustment screw 924 1984 na |
Hi guys, just looking to adjust my brakes. I cannot see the adjustment screw on the back plates? Can anyone enlighten please?
Thanks. _________________ Robert.
Porsche 924 N/A 1984.
Electrical Engineering Sales to Control panel builders. |
Spliffy
Joined: 23 Jun 2009 Posts: 50 Location: North Devon England
Posted: Sat May 09, 2015 3:48 am Post subject: |
The adjuster is accesed via a hole on the backplate looks like a cog and can be rotated with a screwdriver. IIRC its at the bottom of the back plate but its been a while since I did mine. _________________ 1983 N/A
Turbo front brakes
Teledials
Audi T/B
Flush fit screen |
RobertN
Posted: Sat May 09, 2015 4:25 am Post subject: |
Thanks. I can see 3 rubber plugs. I believe one might be for inspecting the shoe wear! I'll take them off any see if I can get at the cog.
RobertN
Posted: Sat May 09, 2015 5:40 am Post subject: |
Removed the rubber plugs and can see the cogs on both recesses but no actual screw head to fit driver into.  _________________ Robert.
Posted: Sat May 09, 2015 6:33 am Post subject: |
Stick a flat screw driver into the cog and pry up or down on the screw driver to adjust the brakes.
 _________________ Stefan
RobertN
Posted: Sat May 09, 2015 7:24 am Post subject: |
Thanks Stefan. I'll try that.  _________________ Robert.
Raize
Posted: Sat May 09, 2015 9:27 pm Post subject: |
| They should be easy to turn. If they're stuck, you need to take the drum off and clean up the threads and re-grease them. don't try and force them as you'll ruin the backing plate. Ask me how I know. |
Posted: Sun May 10, 2015 1:28 am Post subject: |
+1, pop off the drum and inspect/clean/lube the components. It will also help you visualize how the adjustment process should go. _________________ Toofah King Bad
