Ventura77
Joined: 17 May 2015 Posts: 5 Location: Toowoomba, QLD, Australia
Posted: Wed May 20, 2015 9:19 pm Post subject: Standard NA front suspension arms |
Hi guys, I'm rebuilding the front end on my 924, its a standard 4 lug, when I've pulled it down, cleaned it, removed old bushes and such, I had them lightly blasted to ready for paint, but on close inspection of the suspension arms both have a hairline crack right next to the sway bar mounts. What i was wanting to know is can I weld them safely for a fix, because if they are buggered its real hard to find these in Australia. There are plenty for the 85 and on, but they don't have the sway bar mounts _________________ 1980 924, having a full rebuild done, worked NA engine is finished ready for turbo, doing an auto to manual conversion, body kit and re-spray, full custon trim and back seats removed |
Posted: Wed May 20, 2015 10:24 pm Post subject: |
Go ahead and weld them and while you're doing that, add some material along the sides to stiffen them up and bore the new ball joints and holes in the arm for larger, stronger 8mm bolts.
If you need new arms, they are Mk1 rabbit arms with different sway bar mounts (cut yours off and weld them on to the new arms), so that might help your search but won't avoid the welding route.
Good luck! _________________ Stefan
Ventura77
Posted: Thu May 21, 2015 1:18 pm Post subject: |
Thanks mate I'll do that and run some round bar along the edges for strengthing  _________________ 1980 924, having a full rebuild done, worked NA engine is finished ready for turbo, doing an auto to manual conversion, body kit and re-spray, full custon trim and back seats removed |
Tanso
brealytrent
Joined: 28 Dec 2008 Posts: 414 Location: Goldsboro, NC
Posted: Sat May 23, 2015 3:56 pm Post subject: |
The early cars used different mounts for the sway bars, which are much more rare (and expensive). _________________ 1977 Porsche 924 - sold
1980 Porsche 931 - sold
1984 Porsche 928 'S2' Euro - sold
2016 Ford Fiesta ST - sold
2009 Porsche Cayman |
daniel
Posted: Sat May 23, 2015 5:19 pm Post subject: |
Mounts are easy to fab onto the new arms, I'll see if I can upload a photo of what I did. Be aware that the manufacturing tolerance is not good. I run nylon bushes that I got through a group buy, one fit nice and snug and the other arm had a mm clearance with the same bush. Had to pack with some shim material _________________ Over the top of skyline, total brake failure.... hit the wall at over 200 kp/h at the dipper, so anyone who has to brake for the esses is a pussy.
1989 944 Cabriolet |
daniel
Posted: Sun May 24, 2015 11:39 am Post subject: |
Ventura77
Posted: Mon May 25, 2015 8:25 pm Post subject: |
| daniel wrote: |  | By the of the photo the sway bar mounts have been moved outwards from the stock mounts, wouldn't this help to lessen body roll?? _________________ 1980 924, having a full rebuild done, worked NA engine is finished ready for turbo, doing an auto to manual conversion, body kit and re-spray, full custon trim and back seats removed |
daniel
Posted: Tue May 26, 2015 3:25 pm Post subject: |
Sway bars are from a 968CS, slight repositioning was required but there is very little in it. Stock set up with rubbers on the drop link would work in the stock position but as I have ball joints this setup gives no binding _________________ Over the top of skyline, total brake failure.... hit the wall at over 200 kp/h at the dipper, so anyone who has to brake for the esses is a pussy.
