Aussie Jase
Posted: Fri Jun 05, 2015 7:17 am Post subject: Camber plates, which ones? |
Hi guys,
So the 924S lemons car is finally getting a coilover kit, sprayed matt black for cheating purposes
My question is what camber plates should I purchase? They seem to range from $100-$400 searching from Pelican parts to eBay . Remember this car is track only.
What set have you guys used and had success with? Should I get just camber or the camber/caster plates?
Jason. _________________ 1987 924S 24hr LeMons car  |
Posted: Fri Jun 05, 2015 7:34 am Post subject: |
Ground Control sells the very best plates, hands down. My race car has their top mount units, with integrated brace, and my 931 has bottom mounts. _________________ Toofah King Bad
Posted: Fri Jun 05, 2015 1:02 pm Post subject: |
Just bought the ground contol top mount for my next IT-B SCCA car. As Rasta says, it's the best. If you want to be legal for the series you run in, ignore..... _________________ 1979 924 NA race car H-Prod SCCA
Posted: Fri Jun 05, 2015 1:57 pm Post subject: |
For LeMons, just add material to the strut towers and slot or re drill the towers to get the needed camber.
You don't need camber plates for adjustable spring perches and 2.5" springs. The top hats can fit with the stock strut tops.
On our ChumpCar Shadow build we flame wrenched the strut tops and welded in new tips to fit WRX struts. No penalty laps, lowered the car and we gained negative camber. _________________ Stefan
Posted: Fri Jun 05, 2015 4:01 pm Post subject: |
I use new oem mounts and coil over, works fine. Just needed a lite spacer on top of the rod so the coil over spring seat would clear the top mount. I get - 2.9 degrees of camber by the std adjuste. _________________ 1980 924 Turbo
jazz guy
Posted: Sat Jun 06, 2015 12:40 am Post subject: |
I have Ground Control top mounts on the '82 and bottom mounts for the '81. I like their bearing design. _________________ '81/'81/'82 |
