Almost going 77 NA
Goto page Previous  1, 2
PostPosted: Mon Jul 27, 2015 3:24 pm    Post subject: Reply with quote
This is a pretty cool WUR thread IMO.. If you like how CIS makes you crazy then you might like this..
http://924board.org/viewtopic.php?t=20665&highlight=
80 Turbo - Slightly Modified
maybeoneday
PostPosted: Tue Jul 28, 2015 1:35 am    Post subject: Reply with quote
Fasteddie313 wrote:
It's still your WUR..
Was there rust on your valve body surfaces? Your WUR may be just shot if it was that bad..
Figured as much. Yes there was quite a bit of rust on the valve body surfaces. I was going to make the WUR adjustable (control pressure adjustment via the depth on the bi-metallic strip) but decided against it because I was not sure the valve surfaces were good enough to give me a positive result. I cleaned up the rust by dissolving it, and then re polished the roughness from the rust out of the valve surface using a few watchmaking surface finishing tools. I tried to get a consistent flat surface across the valve paying attention to the openings and trying to make sure that they still sealed. obviously I failed. I figured it was worth a try because I was in for a new WUR if I didnt, and I had some chance of not needing one if I did. I may go back in and have another quick look at it before I get myself a new one. I had problems with rounding on one of the screws that held the valve plate down and maybe the tension on this screw is not quite enough so I will replace and see where I am at. I dont think I will try to resurface any more I only wanted to take the minimum amount I could off whilst still removing the roughness from the rust, and I did this (once everything else was freed up the rust on the valve body would have absolutely caused problems in sealing, and it was probably only sealing before because rust had totally blocked the tiny inner ports). I think that the valve surface is as flat as I can get it so no point attempting further flattening.
There is definitely no fuel leaking from the valve body into the WUR (this is one positive at least), just wondering if the extremely fast fuel pressure loss will cause any issues in starting and running cold. As the cold control pressure is ok I would like to at least get it starting consistently while I wait of a new WUR to arrive.
1977 924 NA Auto
PostPosted: Tue Jul 28, 2015 1:58 am    Post subject: Reply with quote
Sounds like you gave it your best shot.
The valve body can come right out of the housing (press fit) so you could try to surface it on a piece of glass with fine grinding compound or something, just an idea.
The warm control pressure is determined by the position of the valve body in the housing, press it in and out slightly to adjust warm control pressure. Cold control pressure is adjusted by the press fit of the post that the bimetallic strip bolts to in the same manner.
Cold control pressure is much less important than warm control pressure, you want your warm control pressure right with no bimetallic strip contact, then you can adjust your cold control pressure via the strip's post..
If you get your cold control pressure right great, it should start good, but the warm control pressure is what makes it RUN good.. I'd trade running problems for starting problems any day, but you can adjust both.
Having inadequate residual pressure is known to cause HOT start problems, this can be worked around by running the fuel pumps before cranking the engine to prime it up.
maybeoneday
PostPosted: Tue Jul 28, 2015 3:34 pm    Post subject: Reply with quote
WRU fixed, just got some better hex head screws that I could tighten with an small hex key, and was a little careful that I used the best side of the metal disk down and got it to hold pressure now. They system as a whole is a little low during leak down but it matters not if the valve on the CIS tester is open or closed. cold control pressure went up a little but so did the temp here and it is still not massively out of range. Now lets just hope this helps with consistent starting and running.
1977 924 NA Auto
PostPosted: Wed Jul 29, 2015 12:11 am    Post subject: Reply with quote
Awesome!! Good work!!
Now.. How is your WARM control pressure? That actually matters.. Forget cold control pressure for now..
Cold control pressure only exists for 2 minutes MAX when you first start your car dead cold, warm control pressure matters all the time and decides your AFR for the most part..
Let the strip heater do its job and see how high the WARM control pressure gets..
maybeoneday
PostPosted: Wed Jul 29, 2015 10:56 am    Post subject: Reply with quote
Yeah ummm, compression usually helps.
I have been chasing my tail with this car for a while. When I got it (for almost nothing from an ex tenant that owed rent and was moving but that is another story) it had a fully recoed head with new valves, a crankcase full of some awful petrol oil mix, a stuck plunger in the fuel dizzy, and it was not going. It took me a while to discover the stuck plunger so I got the fuel dizzy rebuilt. Then I had problems getting it to go, so I left it for a while until I had a little more time on my hands. This time I go in to look at it and I find that the WUR is rusted to the crapper inside so I fix that. The whole time I have a real hard time starting it. This time I am standing there looking at it thinking that I have the base mixture settings done, cold valve clearances done, timing done, spark is good, all the basics for a starting motor and it just farts constantly without going. I am thinking I should probably do a compression test (well actually I was thinking I probably should have done a compression test a long time ago but noting like blind hope that compression is good). test 2 cylinders and get 30psi and 45psi no point going any further compression is shot, and this is probably why it is only farting and not running consistently. Time to stop looking for fuel system problems that explain why it is not starting and pull the god damn engine. Any tips? Want pics?
1977 924 NA Auto
PostPosted: Wed Jul 29, 2015 4:47 pm    Post subject: Reply with quote
Double check valve timing is setup correctly.
If the piston is trying to compress with the valves open you will get low compression.
Then double check ignition timing.
The mention of a reco-ed head tells me valve timing may be out.
Check TDC using the oil pump mark not the flywheel.
(cam pulley can be put on backwards and flywheel can be fitted wrong so check this as well)
PostPosted: Thu Jul 30, 2015 6:33 pm    Post subject: Reply with quote
Can you set the car at TDC and take pics of the cam pulley and pointer, oil pump pointer and crank pulley, flywheel marks and finally the rotor button and dissy.
This will give us an idea of your timing.
maybeoneday
PostPosted: Fri Jul 31, 2015 10:08 am    Post subject: Reply with quote
will do.
1977 924 NA Auto
PostPosted: Fri Jul 31, 2015 10:19 am    Post subject: Reply with quote
Make sure your on the compression stroke TDC by looking at the #1 cylinder cam lobes under the oil cap..
Lobes up = compression stroke
Lobes down = exhaust stroke
The crank (and its marks) goes around twice for every 1 compression stroke, The cam pulley mark is only supposed to line up on the compression stroke TDC (every other crank revolution)..
jason c
PostPosted: Fri Jul 31, 2015 11:28 am    Post subject: Reply with quote
You can feed a screwdriver in the sparkplug hole & feel when the piston comes up on tdc. Turn the crank by hand, go slow & keep the screwdriver loose so you don't put it in a bind.
This will verify if you crank timing marks are correct.
maybeoneday
PostPosted: Tue Aug 04, 2015 4:10 pm    Post subject: Reply with quote
OK, thanks for that. sorry no pics car was wearing me out and I did not want to look at it for a few days.
Got a screw in compression tester from work today and found out lots of stuff.
Firstly timing appears to be ok, I was pretty sure it was right because when I did the valve clearances the cam looked like it was doing the right thing, at the right time, but a double check confirmed this.
Secondly the rubber plug in type compression tester is crappy, and this combined with freshly washed down walls from running rich with no ignition, and me so frustrated with the car I was in no state to be working on it, caused shitty figures.
Thirdly when I got a screw in compression tester on I did get some strange numbers but the other way than what I was expecting, from front to back I got 120, 120 (this cylinder took a while to get to 120 the others stabilised on the 4th time around this was more like the 6th or 7th by the time it settled), 150, 190. That 190 at the end is a little confusing and makes me think maybe I should look at valve clearances again. I would think 190 is too high?? is this right??
This car is killing me, from reading the porsche workshop manual, the haynes, and the CIS bible (all of which I ordered and now have) I have been doing the right things, but I cant seem to explain the non start situation. I seem to have good system pressure and cold control pressure (not sure about warm as I cant start it, I figure that until it goes its not worth worrying about), no vacuum leaks, timing right and base fuel mixture settings as close as possible in a non runner, CSV does not leak, injectors don't drip, with a tight cone (maybe 35ish degrees), and all deliver about (maybe 2-5% difference) the same. From this I am thinking that I need to investigate spark a little more and work out what those compression figures are telling me, maybe a leak down test if all else fails too. I have been working on cars for a while, this is the most difficult one I have seen in ages. Well frustrated, jumping at shadows looking for the fix.
1977 924 NA Auto
Page 2 of 2
