CIS Tuning Assistance
deforiginal
PostPosted: Thu Sep 24, 2015 11:54 pm    Post subject: CIS Tuning Assistance Reply with quote
Ok, after getting all vacuum leaks covered, timed and a new AAV (70 bucks brand new, apparently an 81' 528i AAV works perfect) the car starts and runs. When it warms up you can hit the gas and vroom RPMs go up great but when cold it bogs out. Previous owner messed with both idle and CIS screw so I know it needs to be tuned. What's the best way to tune this without the CIS pressure tool?
DEF Original Automotive
PostPosted: Fri Sep 25, 2015 3:26 am    Post subject: Re: CIS Tuning Assistance Reply with quote
buy (or build) a CIS fuel pressure test gauge set.
Build info here: http://www.924board.org/viewtopic.php?t=38729
Nearly anything else is like getting drunk and trying to shoot yourself in the foot.
PostPosted: Fri Sep 25, 2015 8:33 am    Post subject: Reply with quote
You can't really "tune" with the CIS pressure tool unless your really interested in deep "tuning" of control pressures and system pressure etc..
What you want to do to tune it up is adjust the mixture screw on the fuel distributor and that has nothing really to do with pressure gauges..
If you have a lambda system, O2 sensor, there is a factory test plug just ahead of the firewall in the corner next to the driver's side fender under the hood.. It has 3 pins..
Get yourself a dwell meter and put it on the black wire on that test plug, you are going to aim for 45% duty cycle on 4 cyl dwell scale..
Get your car up to operating temp, get your idle right around 900 ish, nd then tune that mixture screw on the distributor at idle to get your dwell meter as close as you can achieve to 45..
What you are doing is monitoring the duty cycle of the frequency valve and your setting your fuel map/mixture to the middle of your lambda systems adjustable range..
If you don't have lambda then you just want to tune that mixture screw to seat of the pants/plugs/wideband/CO meter, whatever you got..
With your CIS all working well and pressures in spec this is what you do to tune it in, it moves the entire fuel curve slightly richer or leaner throught its entire range, the different/differing fuel pressures and the CIS components themselves set the fuel curves shape.
The airplate opens your system pressure to your injectors, it's like a MAF and a lot of the fuel curve is built into its cone shape, system pressure is the responsibility of the fuel distributor..
Control pressure is responsible for the airplate's resistance to move..
Warm control pressure is for operating temp running, cold control pressure is like a choke along with the cold start injectors help, if you have a turbo then boost also alters your control pressure to richen on boost, all controlled by your WUR - Warm Up Regulator - or control pressure regulator some books call it.
A CIS pressure tester is mostly just to make sure your pressures are in spec, and then tune from spec with that air screw on the distributor..
If you're crazy and want to tune your fuel pressures out of spec for any reason you also use the tester to see your changes, the tester goes into the fuel line between the fuel distributor and WUR with a gauge on the distributor side and a valve on the WUR side completing the WUR line and allowing you to isolate the fuel distributor from the WUR with the valve to see system pressure/distributor pressure, with the valve open you see control pressure/WUR pressure..
80 Turbo - Slightly Modified
nickthompson
PostPosted: Fri Sep 25, 2015 8:41 am    Post subject: Reply with quote
You could realize CIS is crap and dump if for something better.
deforiginal
PostPosted: Fri Sep 25, 2015 8:57 am    Post subject: Reply with quote
Thanks for that, that's what I was looking for. Only problem is im getting 80+ dwell reading and moving the screw wont change it even below 79
PostPosted: Fri Sep 25, 2015 8:59 am    Post subject: Reply with quote
Oh, don't worry he's going to slap Webers on it and solve all the problems!
Never mind the fact that tuning Webers is almost as much of an art as tuning CIS only with more specialized tools and parts required.
PostPosted: Fri Sep 25, 2015 9:38 am    Post subject: Reply with quote
That means you are very lean and putting your engine under load in those conditions is very bad for it..
Look for a vacuum leak anywhere between your airplate and intake valves, this would be just like an intake leak after a MAF..
Or clogged injectors/lines would show you lean like that, or a defective O2 sensor/lambda system, or a clogged fuel distributor, clogged WUR, clogged fuel filter, poor fuel pump delivery, etc..
Try this procedure...
Fasteddie313 wrote:
I'd...
Pull the injectors, Put them in 4 identical pop bottles, jump 30-87 on fuel pump relay to run the pump, Techron in the gas tank, push the metering plate on the fuel distributor to make the injectors spray into your pop bottles..
Go ahead and fill up the pop bottles a couple times to get that Techron through the system, running it is good for it, give it a chance to clean its self up..
Then empty your bottles and fill them about half way with the injectors, compare there levels, the bottles should have equal amounts of gas in them and you should observe a nice cone pattern spray from the injectors.. And it makes very cool sounds.. EEEEEEeeekkkk...
The injectors should stop when your not pushing on the metering plate, a good base setting for the mixture screw is to go rich just until the injectors spray by themselves and then back until they stop while you have the fuel pump running with the metering plate at rest...
If all the injectors don't stop spraying at the same time the ones that continue to spray or dribble while the others are off need to be replaced as they are leaking, give them a chance by running with the techron first..
If your fuel in the tank is questionable maybe you should drain the tank and add fresh fuel first..
If you have access to a CIS fuel pressure testing kit by all means use it, as before run the system with techron for a while first to give it a chance to clean itself up..
If your car has lambda or an O2 sensor system you can then tune the mixture screw by monitoring the lambda frequency valve duty cycle with a dwell meter...
My car is a turbo so small things may differ, dont take my word for gold..
deforiginal
PostPosted: Fri Sep 25, 2015 10:41 am    Post subject: Reply with quote
Thanks again. So far it has a new pump, filter, WUR has been rebuilt, and all vacuum leaks taken care of and hoses replaced. I guess that leaves me wih:
1. Fuel Dist.
2. Lamda system
How much does the lambda system matter? If it controls mix Im not sure why the fuel dist still needs adjustments. Would it be better it kill the lamda and just tune like a carb? On most cars we work on we do dwell off the ignition coil, that is still the same despite the lambda? I will rebuild the fuel dist in the morning to rule that out.
PostPosted: Fri Sep 25, 2015 12:08 pm    Post subject: Reply with quote
1. Fuel Dist.
2. Lamda system
Your lines could be clogged also, WUR return to distributor and main tank return line clogged could cause these symptoms also, your WUR could also be clogged up yet again that fast catching more crap coming out of your fuel distributor. I also highly recommend a CIS testor to be sure your WUR rebuilt or not is functioning within spec and your distributor's system pressure.
You want your lambda to function atleast at its fail safe mode of 45 or 50 % (whatever it is).. If you shut the frequency valve down you loose a lot of fuel flow potential because what the frequency valve does is drop the lower chamber pressure in the fuel distributor to flow more fuel to your injectors via a higher top chamber pressure differential.. Also the lambda system provides WOT enrichment via the frequency valve also by your TB microswitches and you would also loost that WOT enrichment shutting down the lambda system..
If you simply unplug your O2 sensor your frequency valve will default to like 45-50 % duty and will still WOT enrich from the WOT TB switch.. If you have another good/better method of tuning than reading the frequency valve duty cycle with a dwell meter, such as a wideband.. If you want to tune with a wideband you should unplug your O2 like this or the lambda system will fight aainst your tune anyway.. The lambda systems job is to bring you to stioch at idle and cruise conditions the best it can no matter your "tune"..
What you have going on with your frequency valve maxing out its duty cycle is your lambda sees lean, so the lambda is opening the frequency valve as much as possible, to lower the lower chamber pressure, trying to richen you back up to get you back crossing back and forth across stioch as much as it can..
Reading the frequency valves duty cycle is not reading your ignition dwell, it just so happens that a dwell meter is a very good tool, common in the automotive field, that does a very good job of reading a duty cycle.. You are nt reading your ignition dwell doing this, you are reading the duty cycle of the frequency valve that is spit out by the lambda system..
If your at around 45% that is average, in the middle of the lambda systems range of operation, that is the % where it's like "leave it alone" not adjusting richer or leaner but has the ability from there to adjust either way as conditions may require, around the same place it fails to in default mode if your O2 sensor gets unplugged or fails..
Even though the lambda system adjusts your AFRs it only has a small range of operation (that you are exceeding to the lean side), lambda is slow, doesn't adjust at WOT or accel etc.. You still need the airscrew to get into the middle of its range, and it's kinda an emissions thing more than a performance thing other than the WOT enrichment it provides..
It is quite handy for tuning your car though..
IDK what you mean by you are going to rebuild the fuel distributor in the morning, but I wouldn't open it up just yet if I was you..
Run that procedure with a lot of techron in the tank, like a bottle to 1/8 - 1/4 tank of gas or 2 bottles to 1/2 tank, strong mixture, and watch your injectors, compare there levels, swap injectors if levels are different to isolate the problem, and run a LOT of techron laced gas through it so it can clean itsels out, like a couple gallons at least..
ThomasJoseph315
Guest
PostPosted: Fri Sep 25, 2015 9:57 pm    Post subject: Reply with quote
Based on what you have written,.. I think not only is your Fuel Distributor tuned lean, but your injectors are leaking as well. Here is what I would do.
1) Check the plugs,.. bare bones check for rich lean. Also, is any plug worse then the other?
http://www.tuningmatters.com/wp-content/uploads/2014/07/spark-plug-lean-rich-optimal.jpg
2) Check the injectors. The injectors themselves over time don't seat correctly. If they are original injectors, chances are they are bad. A way to check is to get 4 mason jars and with the fuel lines still connected place them in the containers. Next turn on the key to get the fuel pump working, but don't start the engine, just watch the injectors as the pressure builds in the lines, do you see any fuel dripping out of any of the injectors? If so replace any that leak, personally I replaced them all as they are only like $40 each to replace, not too bad and you solve the possibility of clogged injector filters too. If the injectors are leaking, you will never get your A/F ratio tuned right. To check for clogged injectors, raise the fuel dizzy plate with the pump on while injectors are in the jars (take out air filter and push up on it don't pry from top). make sure the jars fill with gas evenly. Also, look at the spray pattern, is it a nice cone pattern to atomize air and fuel or does it look like someone has their thumb over the garden hose? Finally, do a similar leak test with the Cold Start Valve/Injector to check that one as well.
3) Install wide band O2 Sensor, this will help get your A/F ratio fine tuned. A rough tune would be once it's running and up to temp, turn the screw both ways till it begins to stall from being to rich and lean, then put it in the middle. the fine tune would be from driving it on a long stretch of road, getting out and adjusting it based on the gauge reading. The screw you will find once you get into fine tuning is very touchy, any small movement can effect the fine tune. a Hot tip, these cars run better a little rich because German fuel is nearly 100 Octane Vs Us shitty fuel mixed with corn syrup. So 14.7 won't be the ideal, you will have to fiddle with this as everyone's climate and elevation varies. Once you get the optimum right foot feeling, mark it down and use that for reference point for tuning. You will notice that the summer and fall months or day to day temps have an effect on this reading, but general rule of thumb is to tune the car on your yearly average climate temperature day and just deal with the tiny variance for days it's hotter or colder.
4) Idle has nothing to do with A/F ratio. Get the car to idle at 1,500 rpms and adjust the fuel trim as said above, once you got that dialed in, set the idle with a timing gun that you can see the RPMs in the display. Reason for this is you would be surprised what 40 years of resistance can do on a tach. most people are off by 100-150 rpms these days and don't even know it.
5) Check your connectors for AAV and WUR. They are color coded. For me the first year driving having start up issues, one of the many things I've had found is that some monkey swapped the connectors for the WUR and the AAV during the engine swap. They should be connected to the same color male and female. I know sounds simple, but it's happened on my car.
Few other things to check is fuel system filters, The one under the hood is easy, but the tank 90° elbow one is non existent. I got mine rigged up with 2 90° elbows and a straight filter, it works.
Wish you luck! Post a video of the car when it does the issue you describe!
Also, If you need it:
http://www.amazon.com/Tool-Aid-33865-K-Jetronic-Injection/dp/B0002SR5NU
Your just dealing with "Old car" stuff is all.. all the parts you're replacing are beyond the original life expectancy.
Cheers!
