michaelodonnell123
Posted: Fri Dec 18, 2015 3:09 am Post subject: Visibility issues in your 924 - try this |
Hey Everybody -
I was having some issues at night seeing clearly out of my 1988 924S. Here are the steps that made my visibility much better:
Spray the windshield with lots of Windex and used a razor blade to give it a deep cleaning. I did this process twice.
Cleaned the inside and outside of the windshield with alcohol to remove any residue.
Used newspaper and Windex to give both the outside and inside a final good cleaning.
Changed my horrible stock Sylvania headlights to Hella e-Codes. I bought them from Ideola's Garage: http://garage.ideola.com/prod-ElectricsUpgrades.html [Excellent customer service]
Now I can seeing very clearly at night. My visibility has been improved at least 50% better. The e-codes puts out excellent lighting exactly where you need it to be - not only ahead of you but also on the sides.
While nothing I have done is revolutionary or unique - it certainly did help me out and hopefully others as well. _________________ MOD
1988 Porsche 924S
2007 Jaguar XK
2012 Fiat 500 |
Posted: Fri Dec 18, 2015 12:13 pm Post subject: |
I wonder if that's what was wrong with my old RX7...the longer I had it, the harder it was to see out. I finally gave up and sold it. _________________ Toofah King Bad
kcoyle
Posted: Fri Dec 18, 2015 10:46 pm Post subject: |
I was expecting to see a 'vert. Good tips tho. _________________ 1982 931- Stock with MBC at 8psi
pmcaya2
Joined: 24 Nov 2005 Posts: 191 Location: Scio, NY USA
Posted: Sat Dec 19, 2015 1:32 pm Post subject: |
| Thanks for the useful post! I also don't like driving my 924 at night. I will definitely upgrade to H4 per your suggestion. The other problem I have is with reflection from the side-view mirrors when there is a vehicle behind - Probably no solution unless you install some James Bond gadgets. |
Posted: Sun Dec 20, 2015 11:30 am Post subject: |
Or adjust your SIDE view mirrors correctly? If you can see cars directly behind you, they are adjusted wrong.
http://www.caranddriver.com/features/how-to-adjust-your-mirrors-to-avoid-blind-spots _________________ White 87 924S "Ghost"
Posted: Sun Dec 20, 2015 3:46 pm Post subject: |
I second the mirrors aligned incorrectly.
Also the square head mirrors SUCK.
The later 968 pieces are a ton better and can be swapped in.
Unfortunately they are kinda spendy to buy new and rather rare used. _________________ Stefan
Posted: Mon Dec 21, 2015 2:06 am Post subject: |
| fiat22turbo wrote: | Also the square head mirrors SUCK.
The later 968 pieces are a ton better and can be swapped in. |
I agree entirely. Something about the square mirrors makes the passenger side almost unusable for my preferred seating position. I cannot get the square ones adjusted in a way that doesn't require me to lean to the right to get proper field of view.
The 968 mirrors, by contrast, while appearing to have a smaller surface area, are much better positioned and provide greatly improved visibility. I suspect (but don't know for certain) that it is due to a concave mirror surface. _________________ erstwhile owner of just about every 924 variant ever made |
