Cold idle problem
RobertN
PostPosted: Tue May 17, 2016 6:27 am    Post subject: Cold idle problem Reply with quote
Hi Guys, got the emissions done 1.0 and passed the MOT. Good for another year
Next morning she fired up but was very lumpy and struggled to idle at 950 until almost running temp. I had to hold the accelerator pedal slightly to keep her from stalling.
Could she be running too lean or too rich?? How do I maintain good cold idle if my hot idle is perfect!
Thanks.
Robert.
Porsche 924 N/A 1984.
Electrical Engineering Sales to Control panel builders.
PostPosted: Tue May 17, 2016 7:56 am    Post subject: Reply with quote
it could be a little more rich.
I think the maximum for MOT is 2
PostPosted: Tue May 17, 2016 9:14 am    Post subject: Re: Cold idle problem Reply with quote
Not answerable until: a) intake has been tested for leaks on a smoke machine, and; b) fuel pressures have been verified with a proper tester.
RobertN
PostPosted: Wed May 18, 2016 2:15 am    Post subject: Reply with quote
Thanks guys. Emission pass here is 4.5 CO and 1250 HC.
Yes need to invest on a cis tester.
Btw the idle screw is 6 full turns out from its seating point?? Too much?? Idle is around 950 hot.
Robert.
scm924s
PostPosted: Wed May 18, 2016 5:30 am    Post subject: Reply with quote
Your emissions are too low IMHO, these things are best around 2 to 3%, I normally aim for 2.5, but it does vary car to car.
1984 n/a Ruby Red Metallic
1988 924S Guards red- sold
1986 924S Guards Red - sold
1984 n/a Black - sold
1980 n/a Le Mans#1 - sold
1980 n/a Le Mans#2- sold
1977 Martini - sold
RobertN
PostPosted: Wed May 18, 2016 6:07 am    Post subject: Reply with quote
You think I have messed the cold idle as a result of low co adjustment? She was always good before!! When warm she runs really well and starts perfectly.
Robert.
scm924s
PostPosted: Wed May 18, 2016 6:25 pm    Post subject: Reply with quote
Poor cold start can arise from a number of problems, CSV or WUR not operating correctly, but my first thoughts in this case would be too lean a mix at idle
1977 Martini - sold
RobertN
PostPosted: Wed May 18, 2016 7:11 pm    Post subject: Reply with quote
csv okay. How do adjust the mixture from lean to rich? Clockwise turn??
Robert.
scm924s
PostPosted: Wed May 18, 2016 10:23 pm    Post subject: Reply with quote
Yes, but VERY small adjustment has a large effect! Ideally a CO2 meter should be used.
1977 Martini - sold
RobertN
PostPosted: Wed May 18, 2016 10:26 pm    Post subject: Reply with quote
Cheers. I have a Gunson gas tester which I use for the mot tests.
Thanks again.
Robert.
