Appropriate rear brake upgrade for 4 lug?
Noahs944
PostPosted: Sat May 28, 2016 2:41 am    Post subject: Appropriate rear brake upgrade for 4 lug? Reply with quote
Would this be a bolt on solution for the 4 bolt drums?
http://www.mofoco.com/item/EMPI_22_2871_REAR_DISC_BRAKE_KIT_4_130_W_E_BRAKE_IRS_73_79/2747/c138
Power Tryp
PostPosted: Sat May 28, 2016 6:29 am    Post subject: Reply with quote
Those might work. We'd need to get some measurements and contact Empi to see if their bracketry all lines up first. Then spline count and diameter in the drum would also need to be verified.
Finally if everything lines up, you'll have to drill and tap a new bolt pattern in the drum.
Honestly, the kit is a decent price. If you want we can tear into that rear suspension I pulled out of the red car to take measurements from.
Melanie - 1980 931
NoName - 1980 931 (seeking rebuild)
Green tartan interior, you don't see that on a Civic.
PostPosted: Sat May 28, 2016 6:55 am    Post subject: Reply with quote
How often and how hard do you need to break in that 924? Are you sure the brakes are in good working order right now?
I remember my 83 NA brakes as being absolutely superb.
An upgrade would be self adjusting drums from a late car and some performance shoes. Ask the others but maybe a late 924 or early 944 master cyl would also improve the feel of the early brakes.
PostPosted: Sat May 28, 2016 7:52 am    Post subject: Reply with quote
For that money, you could source the used components you'd need for five lug conversion. Of course, you'd still want pads and rotors, but if you got lucky, the donor car might even have usable rotors.
PostPosted: Sat May 28, 2016 8:00 am    Post subject: Reply with quote
I really don't think it is worth investing much money in, a self adjusting system would be great. I did an HPDE school in April and the brakes worked much better than I expected with no fade or problems. That was 8 25 minute sessions over two days. Even though I constantly worried about them they were fine. My only change was to use the Porterfield street grade shoes in the rear, which I'm not sure are worth the money, but probably better than the typical aftermarket shoes. They needed adjusting when done. I put several years of tire wear on that weekend and I'm sure the brakes took the same abuse.
Mike
Kenodog
PostPosted: Sat May 28, 2016 8:20 am    Post subject: Reply with quote
Not surprisingly I have a full 5 lug set up for sale...
Me
1979 Euro 931, Olive
1981 931, Sabine
1996 Ford E-350 ex-FedEx Van
2014 Mazda CX-5 (Kinderwagon)
2019 KTM 790 Adventure
2024 KLX300
2024 KLX140
Power Tryp
PostPosted: Sat May 28, 2016 8:22 am    Post subject: Reply with quote
Haha, my first thought was of you Leigh.
I dunno, I think 4 lug with rear disks would be very unique and barring minor machine work would be simpler.
Melanie - 1980 931
nickthompson
PostPosted: Sat May 28, 2016 9:31 am    Post subject: Reply with quote
If it was the same lug pattern as the 924 it would be more interesting.
Kenodog
PostPosted: Sun May 29, 2016 12:11 am    Post subject: Reply with quote
I guess. Seems like a lot of work though. For $100 less you could have original Porsche parts like vented fron rotors, heavier front 931 springs, Koni stuts etc.
Me
1981 931, Sabine
2024 KLX300
2024 KLX140
JjyKs
PostPosted: Sun May 29, 2016 8:30 am    Post subject: Reply with quote
Well if you'd already drill the holes for right pattern, is there anything that would stop you from drilling the same holes to 5-lug parts?
Raceboy
PostPosted: Sun May 29, 2016 4:54 pm    Post subject: Reply with quote
If one would insist staying 4lug (for example because of some really-really nice wheels or something), it would make sense to use Peugeot rear rotors+calipers. AndrewNZ did it, they work well.
Other than that, just go Porsche 5lug, easy and cheap too.
'83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'90 944 S2 Cabriolet
'78 924 Carrera GT replica
'84 928 S, sold
'91 944 S2, sold
'82 924S/931 "Gulf", sold
'84 924, turbocharged, sold.
Noahs944
PostPosted: Mon May 30, 2016 12:41 pm    Post subject: Reply with quote
Can you lock up your tires at highway speed if you had to?
PostPosted: Mon May 30, 2016 3:41 pm    Post subject: Reply with quote
Ive been tracking both sprint distances and endurance with 125hp and also 12h endurance racing. The drums do just fine with stock liners. I once tried racing liners when I tracked my n/a but it wasnt worth the hassle.
Biggest drawback for me is not braking performance but the constant adjustment you have to do if you track them (having proper play is important to not get dragging shoes when they get hot and expand), and the spongy feel that is hard to get away from.
PostPosted: Mon May 30, 2016 4:52 pm    Post subject: Reply with quote
The idea is NOT to lock up the wheels.
Noahs944
PostPosted: Tue May 31, 2016 12:05 am    Post subject: Reply with quote
When you press the brake pedal all the way (hard-as if you were trying to lock them up) do you feel something bottoming out? Like in the booster or maybe the pedal touching the floor?
