Did i burn the cable
Borken
PostPosted: Thu Jun 16, 2016 12:26 am    Post subject: Did i burn the cable Reply with quote
Hi!
Clever me tried to swap my old rev counter to a fresh one from a 924S. I did not have the same terminals as the old one but one was marked + and the one under it gn (ground?). I tried the signal cable on the other terminals but with no success. I swapped the cables back to to the old rev counter but itīs just as dead as the new one
I no longer have any voltage on the black lead. Of course some of the other meters where dead too, same supply cable i suppose.
The black cable is not fused.
Is my supply cable fried and where do i start looking?
I seems totally intact the little bit that is visible. No fuse box connectors is blackened.
Help!
Jack of all trades, master of none
daniel
PostPosted: Thu Jun 16, 2016 3:08 pm    Post subject: Reply with quote
From memory -
Black is signal wire
Brown is earth
Pink is switched 12v
1989 944 Cabriolet
edredas
PostPosted: Thu Jun 16, 2016 3:32 pm    Post subject: Reply with quote
On the 924S the black wire comes from terminal 87 of the fuel pump relay. If you need to trace the wire, it goes through the firewall and to the 9 pin connector behind the brake booster.
I hope that helps!
'84 944 -Red, Automatic
'87 924S -Red, 300hp 951 swap
'87 924S -Red, Project Car
'88 924S -Red, Daily Driver
Borken
PostPosted: Fri Jun 17, 2016 12:58 am    Post subject: Reply with quote
Ok, thanks for the replys!
The car is a 924 N/A 1981
The black wire is fed from 15 and is positive and goes via the main instrument.
Perhaps something burned out in the instrument?
But my fuse box was tampered with so i will install a better one and go from there.
edredas
PostPosted: Fri Jun 17, 2016 4:31 am    Post subject: Reply with quote
My mistake, I thought you had a 924S and were just swapping another tach in and trying to trace the power wire back to the source.
I'm not sure how you are connecting the 924S tach in the early car, but it should be mentioned that the wiring is of course different colors. So trying to match green wire to black wire will end up a mess. The black wire is positive for this tach and green is signal.
As for the ground, the 924S tach will not work without the ground plugged in for the bulbs on the back of the case.
I hope that helps!
Shurick
PostPosted: Fri Jun 17, 2016 5:10 am    Post subject: Reply with quote
I may be wrong, but 924 tach is different from 924S/944. 924 tach counts pulses from coil negative terminal and 924S is voltage-driven from ECU unit.
WBR, Shurick
'86 924S -- R.I.P.
https://www.instagram.com/ru_pacecar/
edredas
PostPosted: Fri Jun 17, 2016 5:28 am    Post subject: Reply with quote
The 924S/944 DME sends pulses to the coil and the tach just reads those. These pulses aren't any different than the early cars. A guy once asked me to make his 924S look like an early 924 inside so I swapped the speedo, tach, clock, and oil pressure gauge over from a '77 924. I only had verify the wiring and everything worked perfectly!
Ian89C4
PostPosted: Fri Jun 17, 2016 6:34 am    Post subject: Reply with quote
If I remember correctly
924 (non S)
Green - Signal wire from negative side of coil (should be a two wired connector at the coil
Black - 12V
Brown - Ground
I haven't messed with a stock wiring loom in a few years, so where the power comes from I don't exactly recall.
Check you grounds behind the fuse box. There are two "wheels" of them attached the sheet metal behind the fuse box. They are usually very corroded if they haven't been tended to in 30+ years. That may be where your problem is.
Good luck,
Ian
Ian Edgerly
North Carolina
Current:
1980 924 Euro ("Wahala")
Borken
PostPosted: Sat Jun 18, 2016 1:27 am    Post subject: Reply with quote
Yes that wiring was correct!
I swapped the fuse box and now i believe my electric system works 100%
/janne
Ian89C4
PostPosted: Sat Jun 18, 2016 12:04 pm    Post subject: Reply with quote
Great!
Ian Edgerly
North Carolina
Current:
