Fuel sending unit testing
awolak
PostPosted: Wed Jul 06, 2016 11:04 am    Post subject: Fuel sending unit testing Reply with quote
I'm testing my fuel sending unit from an 82 924 N/A and according to the Haynes manual I should have approx. 85 ohms between the W and G spades in the upright position. When I do this I am getting 71.5 ohms (low level reading). The manual says that when inverted there should be 4.75 ohms but my meter reads the default "1"(high level reading). I had tested the unit for the low level lamp and it is working fine.
The reason I am doing the testing is because my low level lamp is on but my gauge reads just under 1/4 tank and I know that I don't have that much fuel in the tank plus now I know my low level lamp is working.
Is there a way to repair these or do I have to buy a new one?
Thanks in advance.
1982 924 N/A
2011 Nissan Rogue Krom
2006 Range Rover Sport HSE
2002 BMW 330 CI
2000 Audi A6 Quattro
2000 Chevy Tahoe LS
awolak
PostPosted: Thu Jul 07, 2016 5:12 am    Post subject: Reply with quote
found a good write up here:
although it states for a 911 the unit is similar
http://www.pelicanparts.com/techarticles/911_fuel_tank_sender_replace/911_fuel_tank_sender_replace.htm
1982 924 N/A
2002 BMW 330 CI
2000 Chevy Tahoe LS
PostPosted: Thu Jul 07, 2016 5:19 am    Post subject: Reply with quote
There is also this excellent write-up on our very own 924.org tech section:
http://www.924.org/techsection/gas_sender.htm
awolak
PostPosted: Thu Jul 07, 2016 8:04 am    Post subject: Reply with quote
I searched and couldn't find anything, of course this one is better. Thanks
1982 924 N/A
2002 BMW 330 CI
2000 Chevy Tahoe LS
awolak
PostPosted: Fri Jul 08, 2016 1:14 am    Post subject: Reply with quote
After being correctly directed to the tech section on this site, I disassembled and cleaned the sending unit connections and wires with a vinegar/salt solution. I then neutralized the acidity with a baking soda/water mix. I dried all of the connections with compressed air and re-assembled. I am still having the same problem as to where the fuel gauge reads 1/4 tank when it should be reading empty. When I invert the unit the gauge does read full as it should. Any suggestions?
1982 924 N/A
2002 BMW 330 CI
2000 Chevy Tahoe LS
PostPosted: Fri Jul 08, 2016 1:26 am    Post subject: Reply with quote
1. Try again.
2. Check all grounds, especially the ground crown at the rear of the car between the tail lights.
awolak
PostPosted: Fri Jul 08, 2016 3:29 am    Post subject: Reply with quote
Thanks for the reply,I cleaned that set of grounds when I performed the initial test. I ended up taking the gauge cluster out of the dash and cleaning both connections on gauge and plug. Works fine now.
Thanks again
1982 924 N/A
2002 BMW 330 CI
2000 Chevy Tahoe LS
