Weber Big Throat Throttle Body. Help Please.
nivekrs
PostPosted: Thu Oct 20, 2016 8:18 am    Post subject: Weber Big Throat Throttle Body. Help Please. Reply with quote
Hello. I recently purchased I new in box Weber Redline Big Throat Throttle Body from an eBay seller. I took it out of the box today to compare it to my stock TB and noticed that it doesn't seem to have provision for the electrical connections which are mounted and used in conjunction with the throttle cable lever on the stock TB. I have a 1982 924 NA. Any advice, help or solutions would be greatly appreciated.
Fifty50Plus
PostPosted: Fri Oct 21, 2016 9:57 am    Post subject: Reply with quote
Put the big throat back on e-bay.
1982 924 NA race car - Sold
1981 924 Turbo sold
1982 924 Turbo sold
Spliffy
PostPosted: Sat Oct 22, 2016 3:02 am    Post subject: Reply with quote
What electrical connections ? take it its an american market thing ? my euro spec 1983 N/A doesn't have any
1983 N/A
Turbo front brakes
Teledials
Audi T/B
Flush fit screen
PostPosted: Tue Nov 01, 2016 11:33 pm    Post subject: Reply with quote
If this TB is a good rout to a TPS I may be interested..
lmk
80 Turbo - Slightly Modified
PostPosted: Wed Nov 02, 2016 2:27 am    Post subject: Reply with quote
US cars have two microswitches that are used in conjunction with the O2 sensor / Lambda system.
You can either abandon those connections and disconnect the O2 sensor, which will essentially allow the car to run in open loop mode (not as good for the environment, not as good for fuel economy, but should have minimal impact to performance); or you can figure out how to install an S2 931 throttle position sensor on the Weber TB and figure out how to connect the microswitch leads to the TPS. This is not as big of a deal as it sounds, as the same steps are necessary when converting an S1 931 to an S2 throttle body and intake manifold. I don't recall the pinout offhand, but there should be some instructive posts here on the board if you're clever enough to find them with Google site search.
