crankshaft bolt
ted von Kampen
PostPosted: Wed Nov 02, 2016 4:48 am    Post subject: crankshaft bolt Reply with quote
After several days of working, O finally got the crankshaft bolt off my 924 2liter (1981). I tried several methods, including an air impact wrench that would not work. Finally resorted to making a tool that bolted to the cam belt pulley (6 holes) and using an impact 24mm socket with about a 4 foot leverage bar (ie-pipe over breaker bar). With about all the strength I could muster I finally loosened the bolt. Which brings me to my question. The Haynes book says the torque spec on this bolt is 180 ft-lbs. Does it really need to be that tight? Your experienced based comments are welcomed. Thanks, Ted
PostPosted: Wed Nov 02, 2016 3:02 pm    Post subject: Reply with quote
180 isn't that tight...it wasn't torque that made it hard to remove.
ted von Kampen
PostPosted: Thu Nov 03, 2016 1:44 am    Post subject: Crank bolt Reply with quote
Thanks for the comment. What do you think made it that tight? I have seen and heard forum comments that the crankshaft bolt is often very tight. Other engines I have rebuilt are on the order of a 100 ft-lbs or so.
PostPosted: Thu Nov 03, 2016 1:51 am    Post subject: Reply with quote
Seizing through corrosion and/or dissimilar metal bonding.
To hit 180 you only have to pull 90 lbs on a two foot breaker. Like I said, not that tight.
PostPosted: Thu Nov 03, 2016 3:21 am    Post subject: Reply with quote
The 2.0L motor is known to have some ridiculous levels of vibration, is probably why...
I go with 180ft-lbs plus red loctite.
