chris79
Posted: Wed Nov 16, 2016 8:23 pm Post subject: Timing setttings |
I replaced timing belt and fuel pump. Now I set timing at -10°, but performances are not good , 0-100km in about 13s.
I found this photo on internet, timing is not -10° but first mark before 0.
What's correct timing setting for 924 na 125hp?
Thanks _________________ Porsche 924 2.0 na 125hp (1979) euro
Alfa Romeo Spider "Duetto" 1.6 104hp (1986) euro |
Posted: Wed Nov 16, 2016 9:16 pm Post subject: |
Do you have a Haynes manual? it should be written there.
Also, in the engine bay you should have a sticker that tells you what the advance should be. _________________ Supercharger and EFI kits
chris79
Posted: Thu Nov 17, 2016 2:34 am Post subject: |
I have no haynes manual and now even online version is out of service.
The oil pump mark is aligned to flywell mark on 0, it't possibile that exact timing is 0 on this version? Now I aligned even mark on camshaft to this value. Is enough or I have to set some advance? _________________ Porsche 924 2.0 na 125hp (1979) euro
brian19600
Posted: Thu Nov 17, 2016 3:04 am Post subject: |
From Haynes:
1976-1980 European models, 125hp engine:
10 degrees before top dead center at 950 +- 50rpm with vacuum hoses disconnected _________________ 78 924 |
chris79
Posted: Thu Nov 17, 2016 5:46 am Post subject: |
| brian19600 wrote: | From Haynes:
10 degrees before top dead center at 950 +- 50rpm with vacuum hoses disconnected |
No ignition timing, but valve timing.
The oil pump mark is aligned to flywell mark on 0. Then I have to align even crankshaft mark exactly or I have to made some advance ? _________________ Porsche 924 2.0 na 125hp (1979) euro
Posted: Thu Nov 17, 2016 5:59 am Post subject: |
Crank and Camshaft must align.
Ign timing is 10 deg but find mine likes 8 unless I use 98 RON fuel which is $6 a US gallon _________________ Porsche 924 1984 (UK import) NA
KDJones2000
Posted: Thu Nov 17, 2016 7:19 am Post subject: |
Timing marks are on the FLYWHEEL, not the front of the engine.
There is an opening near the master cylinder in the bell housing you need to use to set your timing. _________________ 1987 924S SPEC car
Team Toofah Racing
1988 944 Turbo S |
chris79
Posted: Thu Nov 17, 2016 7:45 pm Post subject: |
Ok but my question is when Mark on camshaft is centered, Mark on flywell must be -10, 0, +10, One Mark before or after zero, ecc ? _________________ Porsche 924 2.0 na 125hp (1979) euro
pierro
Posted: Thu Nov 17, 2016 9:38 pm Post subject: |
With cylinder 1 at TDC, the camshaft AND the crankshaft pully on their MARKS, the flywheel mark should be on 0 degrees.
The IGNITION timing for a 924 na is -10degrees on the flywheel markings, checked with a stroboscope ( timing light) at 950rpm and the vacuum hose disconeccted from the distributor. _________________ Porsche 924 1983restored
MG-Midget 1974 restored
Citroen 2CV 1986 restored
Rover Mini 1275 1992 restored
Mazda MX-5 1.8 for the fun
Toyota Lancruiser Prado daily driver
Merceds Benz W124 230E for the quality |
chris79
Posted: Fri Nov 18, 2016 4:43 am Post subject: |
Ah ok thanks, all Mark have to match.
However, if it can be usuful, there is even Mark on oil pump and I verified this on my car.
http://www.porscherepair.us/porsche-924-engine/installing-drive-belt.html _________________ Porsche 924 2.0 na 125hp (1979) euro
Posted: Fri Nov 18, 2016 7:06 am Post subject: |
The mark on the crank pulley and oil pump should align with the flywheel mark.
If they dont the flywheel was refitted wrong. _________________ Porsche 924 1984 (UK import) NA
chris79
Posted: Fri Nov 18, 2016 4:31 pm Post subject: |
Yes, three marks match , now I have only to set advance with timing light. _________________ Porsche 924 2.0 na 125hp (1979) euro
