Timing setttings
chris79
PostPosted: Wed Nov 16, 2016 8:23 pm    Post subject: Timing setttings Reply with quote
I replaced timing belt and fuel pump. Now I set timing at -10°, but performances are not good , 0-100km in about 13s.
I found this photo on internet, timing is not -10° but first mark before 0.
What's correct timing setting for 924 na 125hp?
Thanks
Porsche 924 2.0 na 125hp (1979) euro
Alfa Romeo Spider "Duetto" 1.6 104hp (1986) euro
PostPosted: Wed Nov 16, 2016 9:16 pm    Post subject: Reply with quote
Do you have a Haynes manual? it should be written there.
Also, in the engine bay you should have a sticker that tells you what the advance should be.
chris79
PostPosted: Thu Nov 17, 2016 2:34 am    Post subject: Reply with quote
I have no haynes manual and now even online version is out of service.
The oil pump mark is aligned to flywell mark on 0, it't possibile that exact timing is 0 on this version? Now I aligned even mark on camshaft to this value. Is enough or I have to set some advance?
brian19600
PostPosted: Thu Nov 17, 2016 3:04 am    Post subject: Reply with quote
From Haynes:
1976-1980 European models, 125hp engine:
10 degrees before top dead center at 950 +- 50rpm with vacuum hoses disconnected
chris79
PostPosted: Thu Nov 17, 2016 5:46 am    Post subject: Reply with quote
brian19600 wrote:
From Haynes:
No ignition timing, but valve timing.
The oil pump mark is aligned to flywell mark on 0. Then I have to align even crankshaft mark exactly or I have to made some advance ?
PostPosted: Thu Nov 17, 2016 5:59 am    Post subject: Reply with quote
Crank and Camshaft must align.
Ign timing is 10 deg but find mine likes 8 unless I use 98 RON fuel which is $6 a US gallon
KDJones2000
PostPosted: Thu Nov 17, 2016 7:19 am    Post subject: Reply with quote
Timing marks are on the FLYWHEEL, not the front of the engine.
There is an opening near the master cylinder in the bell housing you need to use to set your timing.
1987 924S SPEC car
Team Toofah Racing
1988 944 Turbo S
chris79
PostPosted: Thu Nov 17, 2016 7:45 pm    Post subject: Reply with quote
Ok but my question is when Mark on camshaft is centered, Mark on flywell must be -10, 0, +10, One Mark before or after zero, ecc ?
pierro
PostPosted: Thu Nov 17, 2016 9:38 pm    Post subject: Reply with quote
With cylinder 1 at TDC, the camshaft AND the crankshaft pully on their MARKS, the flywheel mark should be on 0 degrees.
The IGNITION timing for a 924 na is -10degrees on the flywheel markings, checked with a stroboscope ( timing light) at 950rpm and the vacuum hose disconeccted from the distributor.
Porsche 924 1983restored
MG-Midget 1974 restored
Citroen 2CV 1986 restored
Rover Mini 1275 1992 restored
Mazda MX-5 1.8 for the fun
Toyota Lancruiser Prado daily driver
Merceds Benz W124 230E for the quality
chris79
PostPosted: Fri Nov 18, 2016 4:43 am    Post subject: Reply with quote
Ah ok thanks, all Mark have to match.
However, if it can be usuful, there is even Mark on oil pump and I verified this on my car.
http://www.porscherepair.us/porsche-924-engine/installing-drive-belt.html
PostPosted: Fri Nov 18, 2016 7:06 am    Post subject: Reply with quote
The mark on the crank pulley and oil pump should align with the flywheel mark.
If they dont the flywheel was refitted wrong.
chris79
PostPosted: Fri Nov 18, 2016 4:31 pm    Post subject: Reply with quote
Yes, three marks match , now I have only to set advance with timing light.
