No fire on freezing mornings on my '79 924
CorsePerVita
PostPosted: Tue Nov 29, 2016 6:39 am    Post subject: No fire on freezing mornings on my '79 924 Reply with quote
The '79 has been running like a champ, even when it's colder outside. However, every time we have a freezing morning, the damn thing will not start.
It cranks, and it cranks quickly as it should, so it isn't a weak starter issue. I bought a new battery. The coil is about a year old or so... and is original Bosch NOS coil for the '79, factory.
New cap, rotor, plugs, wires. New fuel filter. Injector cleaner recently ran through.
Car cranks and cranks and cranks but acts like it isn't firing as all. Doesn't cough, doesn't spit. Nothing. Just endlessly cranks.
I am completely baffled as to what it may be. It's never done this before and is confusing the living hell out of me.
I managed to get it one morning with some starter fluid, but it also wasn't totally freezing outside. Soon as the ice comes, so does my no start. I'm starting to get annoyed to hell when it does this, because it didn't used to do this and just started doing this and I have no idea what is causing it.
- 1980 Porsche 931 (Daily)
- 1987 Lamborghini Jalpa
- 1999 Ducati 900SS
michaelodonnell123
PostPosted: Tue Nov 29, 2016 7:44 am    Post subject: Reply with quote
Maybe a lazy/tired fuel pump that just doesn't work as hard as it needs to in freezing weather.
MOD
1988 Porsche 924S
2007 Jaguar XK
2012 Fiat 500
pcelenta
PostPosted: Tue Nov 29, 2016 7:59 am    Post subject: Reply with quote
Did you check the cold start injector and auxiliary air valve?
CorsePerVita
PostPosted: Tue Nov 29, 2016 8:01 am    Post subject: Reply with quote
I would think that if it was the fuel pump, the car would at least sputter on starting fluid, and it doesn't even do that. I suppose I can't leave anything out and can try to test the pressure coming from the pump cold and warm.
I actually haven't tested the cold start injector. Good idea. Though why would it do that in the cold only? Only freezing temps? It starts OK on other cold-ish mornings, just not below freezing. Also haven't tested aux air valve, but I wouldn't think that'd cause a complete no start even with using starting fluid.
- 1999 Ducati 900SS
Lau Christophersen
PostPosted: Tue Nov 29, 2016 9:24 am    Post subject: Reply with quote
Water somewhere in the system?
76 924 (PARTS)
77 924 (PARTS)
77 924 converted to 924S
77 928
79 931
79 931(PARTS).
79 931 Carrera GT look (PARTS).
79 931 with VEMS and opgrades
81 928S +30 cm widebody kit
82 924 (SOLD)
83 928S
86 944
86 944 (S2(SOLD))
89 944 S2 (SOLD)
CorsePerVita
PostPosted: Tue Nov 29, 2016 9:46 am    Post subject: Reply with quote
Sure, but where? And how would that effect it only on freezing mornings? I mean, I drive the thing in the rain all the time and it's never had a single issue. I'm open to all ideas though. I'm going to start with AAV, coil test, and cold start injector tonight when I get home.
- 1999 Ducati 900SS
pcelenta
PostPosted: Tue Nov 29, 2016 12:01 pm    Post subject: Reply with quote
On the cold days you are going to need some extra fuel to start it up. If the cold start injector is not functioning you may have a difficult time kicking it over when it is stone cold. The auxiliary air valve could be stuck closed. This can also make it very difficult to start when cold. Also. Check all your vacuum lines.
PostPosted: Tue Nov 29, 2016 5:23 pm    Post subject: Reply with quote
Check the plugs if they are wet after a cranking but no start session.
If they are not wet then you aren't getting fuel.
If they are wet check if if you have spark.
If you have spark check that you have a good spark not a flimsy one.
If you have fuel and good spark check the compression.
