Turbo bypass valve
knobby
PostPosted: Fri Oct 26, 2018 8:34 am    Post subject: Turbo bypass valve Reply with quote
I just got my turbo back from Majestic and have to replace the bypass valve gaskets myself because they thought that they were NLA!
Anyway I need help with the piston orientation.
I think the piston crown faces the opposite side to the vacuum elbo.
There are two slots on the crown and I need to know if they need to be oriented in a specific way or doesn’t matter.
Also a slot cast that is visible from the underside of the piston.
Any help appreciated as I’d really like to get this right before installing it this weekend.
81 RED 931 S2(daily driver),81 WHITE 931 S2(not currently drivable).
Cincinnati,Ohio
PostPosted: Fri Oct 26, 2018 9:46 pm    Post subject: Reply with quote
Per the parts manual, the piston looks to be installed with the flat face opposite the inlet elbow (boost sensing line from intake), or facing the RHS of the car... and the spring on the LHS of the car/on the vacuum elbow side... make sense? Sounds like what you were expecting for orientation.
Can't offer any ideas regarding rotational orientation, sorry.
Definitely want to get that sorted now; I made the mistake of getting it backwards, and had to fix in-car, which sucked (but was just barely doable)...
PostPosted: Sun Oct 28, 2018 12:15 am    Post subject: Reply with quote
Not aware of orientation of the slots. I don’t believe it matters. Had mine in and out twice and did not consider this. There is nothing to stop the piston spinning except spring friction anyhow.
knobby
PostPosted: Mon Oct 29, 2018 1:02 pm    Post subject: Reply with quote
I eventually spoke to the tech at Majestic who confirmed that the rotational orientation of the piston slots was vertical when he disassembled the turbo but John stated that it did not matter.
Any way I installed it this weekend and am very happy with it!
Thanks for your replies,much appreciated!
Cincinnati,Ohio
