Spark Plugs
newbie924
PostPosted: Mon Mar 04, 2019 2:19 am    Post subject: Spark Plugs Reply with quote
I am using Denso plugs K16 TR11,, I am not sure if these are appropriate for the 924NA.. the last plug is getting shorted or found wet with petrol.. could I be using the wrong plugs? or is the engine fuel supply too rich?
safe
PostPosted: Mon Mar 04, 2019 7:42 pm    Post subject: Re: Spark Plugs Reply with quote
Without knowing what kind of plugs that is, I would guess that its rich.
Does it smoke and smell rich?
If the plugs has gotten this wet, throw them away and get new ones. Get the recommended Bosch or NGK (from the manual), after that you can adjust the heat range if needed (probably not).
newbie924
PostPosted: Mon Mar 04, 2019 10:02 pm    Post subject: Reply with quote
It does not smell that rich and has stopped smoking, since it was left standing by the previous owner.. I will see what the manual says and test try some plugs i guess... It does start first try working on 3 plugs though which is surprising in a way,, but obviously wont rev up due to the bad wet plug.
safe
PostPosted: Mon Mar 04, 2019 10:07 pm    Post subject: Reply with quote
A wet plug will never work good, if at all.
You can have bad spark plug wires too (or plug connectors for that matter), if you have any doubt change them. Generic wires are cheap.
newbie924
PostPosted: Mon Mar 04, 2019 11:19 pm    Post subject: Reply with quote
I have decided to maybe even change to electronic spark too since the distributor has points,,and these seem to clog up in time... the car is a 78 model....
safe
PostPosted: Mon Mar 04, 2019 11:32 pm    Post subject: Reply with quote
Not sure what the cost would be and if it would be worth it. Points are not that bad, they wear a little but are cheap. They can get dirty but are easy to clean, just remember to NEVER use an abrasive paper on them, that will only work as a quickfix, but will soon cause issues again.
A game changer would be to go to a programmable distributorless system (Mega Jolt for example). This way you can get rid of mechanical issues with worn parts and easily adjust timing precisely.
PostPosted: Tue Mar 05, 2019 12:20 am    Post subject: Fouled injector? Reply with quote
If it was left sitting for some time - I'd also wonder if perhaps the injector for that cylinder might be clogged a bit and not giving a good even spray... so no good dispersal/atomization of the fuel, just dumping a stream, could act like an over-rich condition, but only that one cylinder... might be worth pulling it out and checking it...
PostPosted: Tue Mar 05, 2019 12:21 am    Post subject: Reply with quote
Do an injector flow test to determine if they are all delivering an equal amount of fuel.
Do a compression test.
Are you losing any coolant?
Also be aware you probably have a lot of fuel in your oil.
newbie924
PostPosted: Wed Mar 06, 2019 6:33 am    Post subject: Re: Fouled injector? Reply with quote
Noted with interest.
newbie924
PostPosted: Wed Mar 06, 2019 6:43 am    Post subject: Reply with quote
I haven't given it a good run for now since Im still tidying it up a bit and getting the body and interior in order since I need to get it taxed and it needs to go thru a road worthy test before I can tax it. But I do start him up and there is no sign of water loss... though I do suspect that the previous owner might have attempted to start it without success since the cars timing and plug leads were terribly faulty and mixed up, so I do suspect there could be some fuel in the oil. I had in mind to change it once this problem of wetting the plug is resolved though. The car at first was letting up smoke from the exhaust too which has now since stopped also.. I think that the cause of such problems is letting the car standing and best thing to do is go thru the ignition and fuel system as suggested and clean/tidy/change anything or everything. I also intend to put some Lucas injector cleaner in with the fuel once everything is tidy'd up as well.
PostPosted: Wed Mar 06, 2019 8:47 am    Post subject: Reply with quote
I've gone with plugs 2 hotter than the manual recommends. Otherwise they tend to foul with oil after a while.
I also run a higher octane fuel to be safe with the hotter plugs.
78 924 NA
5-lug
newbie924
PostPosted: Thu Mar 07, 2019 9:08 pm    Post subject: Reply with quote
Can you share the plugs number code?
safe
PostPosted: Thu Mar 07, 2019 10:16 pm    Post subject: Reply with quote
Beware that heat ranges aren't universally exchangeable.
According to design911.co.uk (just googled "924 spark plugs")
The 924 uses Bosch WR5DC or WR5DC+, the 931 the colder WR4DC
Get plugs in a heat range you think good, get one with small thin electrode (Iridium?) they keep themselves cleaner in my experience. Multiple ground electrodes are a waste of money, they are for extended service intervals (100.000 km).
PostPosted: Fri Mar 08, 2019 10:48 pm    Post subject: Reply with quote
Adding on to this... had a bitch of a time trying to chase the correct new Bosch part #'s down. Seems that Rock Auto have been listing the WR6DC plug for the Turbo... maybe this helps explain why my plugs are fouling constantly, not just maybe some turbo oiling???
OTOH, when I look at the parts manual, I see WR6DS (silver conductor, no big deal) listed for both 924 and Turbo?
Anyway: WR5DC = Bosch 7992 in the new parts numbering scheme.
They're like $1.60 from Rock Auto, so I'll give 'em a shot, see how she goes...
Edit - I got it backwards, the WR6 will be hotter than the WR5... oh well, these'll come in handy when the boost comes up... meantime gotta wait on my turbo rebuild and hope that'll help clean up some of the funk the engine keeps ingesting... and a little more oomph besides!
I also wonder if there's perhaps some variation here EU vs. US spec plugs...
Fifty50Plus
PostPosted: Sat Mar 09, 2019 2:36 am    Post subject: Reply with quote
I put Bosch plugs in customer engines when they insist. Otherwise I use the No Good Kind. I've had problems with Bosch plugs fouling on all my race cars over 40 years until I switch to NGKs - never had a problem with them.
Just a data point....
1982 924 NA race car - Sold
1981 924 Turbo sold
1982 924 Turbo sold
