6.10 vs 4.10 Turbine Housings
Goto page 1, 2, 3  Next
Mike9311
PostPosted: Sun Mar 24, 2019 7:29 am    Post subject: 6.10 vs 4.10 Turbine Housings Reply with quote
Just figured I'd show the difference for our tech section. Came out really obvious painted white and at these angles. Obviously 6.10 on LEFT and 4.10 to the RIGHT
1980 931 since 1989
1981 Ideola 931 Club Sport
1982 931 Entwicklungsfahrzeug
1979 924 NA ohne 650 mit 471
1980 924 NA (R&D lightweight)
1982 931 wana-be GTR race car
PostPosted: Sun Mar 24, 2019 6:45 pm    Post subject: Reply with quote
I’ll take the one on the left please ....
Mike9311
PostPosted: Mon Mar 25, 2019 11:54 pm    Post subject: Reply with quote
When you handle them they don't seem so different but at these angles its soooo obvious
1980 931 since 1989
PostPosted: Tue Mar 26, 2019 4:17 am    Post subject: Reply with quote
Nice view, should be 4 sq cm vs 6 sq cm area at the inlet throat according to the TB there should be some different versions around with some durability tweaks aswell. Not sure what they did though.
PostPosted: Tue Mar 26, 2019 4:23 am    Post subject: Reply with quote
Thanks for the pictures.
80 Turbo - Slightly Modified
PostPosted: Tue Mar 26, 2019 6:43 am    Post subject: Reply with quote
Only difference I am aware of is adding in a step to later manifolds and turbine housing intake to install a fire ring/collar to in theory help protect the gasket from heat and leaks. I haven't run this fire ring for 4 yrs and gasket stayed intact.
Mike9311
PostPosted: Sat Apr 06, 2019 12:17 am    Post subject: Reply with quote
Its interesting since they share basically the same inlet but the 4.10 chokes hard once it starts the scroll. No wonder it has nothing to give at higher boost. This is the 6.10 below. I need to redo a few things but its too cool not share. Also picked up another '82 931 but that's another story
Anyway, you guys can probably figure out where I am going with this. Working on the CAD model already
1980 931 since 1989
PostPosted: Sat Apr 06, 2019 12:24 am    Post subject: Reply with quote
Not sure it chokes but should accelerate the hot gasses and gives a faster spool, certainly on lower rpm + lower boost. For sure on higher boost cars the 6.10 would have longer legs I guess.
Mike9311
PostPosted: Sat Apr 06, 2019 12:31 am    Post subject: Reply with quote
Chokes may not be the right word for it but it gets much smaller when compared to the 6.10.
1980 931 since 1989
PostPosted: Sat Apr 06, 2019 2:27 am    Post subject: Reply with quote
cool stuff, thanks for sharing
PostPosted: Sat Apr 06, 2019 5:06 am    Post subject: Reply with quote
Choking is not a bad choice of word, turbine swallowing capacity is a word used with the turbo suppliers. The smaller turbine housing builds higher pressure ratio. And turbine power is created by Pressure Ratio, temperature , and massflow.
Below is how a turbine map looks like, the top of the map is where the turbine chokes, as you can see the efficiency drops significantly aswell, so maxing out a small turbine housing have kind of a double negative impact. The bad efficiency will make turbo need even more pressure ratio (closed waste gate) to drive the compressor, and back pressure will increase even more, increasing detonation risk and creating pumping work for the engine (which reduces power).
The turbine should be matched with the map, but those are very seldom shared, which is annoying. And of course its more complicated with the pulsating flow compared to the compressor.
Really nice scans, send them to china and reproduce them in some high temp alloy/cast steel
Mike9311
PostPosted: Sat Apr 06, 2019 5:32 am    Post subject: Reply with quote
Thanks for the lesson!
That is the plan but not China. Little too worried about a few things if I send it there
1980 931 since 1989
PostPosted: Sat Apr 06, 2019 6:14 am    Post subject: Reply with quote
Yep, we need a new source of #6 turbine housings due to cracking.
Kenodog
PostPosted: Mon Apr 08, 2019 3:40 am    Post subject: Reply with quote
I have a NOS 6.10 housing if someone wants to have it recast. I was going to do that with exhaust manifolds years ago, have them recast in inconel, but I didn't think people here would be down for the $500 ea price tag when you can simply weld up the cracks on your old one.
IIRC the mold was going to be $5,000 ($Cdn) and then it was $2 lb for the inconel. . .
Me
1979 Euro 931, Olive
1981 931, Sabine
1996 Ford E-350 ex-FedEx Van
2014 Mazda CX-5 (Kinderwagon)
2019 KTM 790 Adventure
2024 KLX300
2024 KLX140
jacobroufa
PostPosted: Tue Apr 09, 2019 1:17 am    Post subject: Reply with quote
I don't know a lot about this stuff, but an engineer friend informed me that ProtoLabs will 3d print in 718. If you've got it scanned already would not that be a less expensive option?
1980 Porsche 931
1981 Porsche 924 Weissach
Page 1 of 3
