Oil filter came loose.. AGAIN!!!!!!!!!!
PostPosted: Tue Jul 14, 2020 8:25 am    Post subject: Oil filter came loose.. AGAIN!!!!!!!!!! Reply with quote
I'm a bit aggravated..
This is the 2nd time my oil filter has worked itself loose and blew an oil slick all down the road.. This time I saw it very fast and shut down immediately.. Still some oil on the dipstick this time..
Same thing.. Cold engine.. Just getting up to speed, just get into 4th, accelerating slowly with no boost (cold), SMOKE, shut down..
Good thing the exhaust gets hot fast to make smoke..
Only like a mile from my house.. Pulled it back again already..
This filter isn't even a year old and I know darn well I put it on tight.. Real tight.. Because this just happened not too long ago so I know darn well I put it on wayy tight with a filter wrench and everything so this wouldn't happen again.. BUT IT HAPPENED AGAIN!!!!!!!!!!!!
Maybe it was a bit funny the first time, but now it's not..
Has this happened to anyone else?
What can I do about it?
Ideas so far..
Bugger up the threads in the oil filter to make a bit of a lock-nut out of it?? <best idea so far.. Take a punch and hammer and whack the threads in the back a bit?
or..
Wire the thing up somehow after I put another new filter on it, like safety wire, but it's round, so IDK..
What the heck is going on?
After all this engine has been through, I'll be mad if a stupid oil filter is what does it in..
80 Turbo - Slightly Modified
PostPosted: Tue Jul 14, 2020 11:17 am    Post subject: Reply with quote
Check your oil pressure relief valve.
PostPosted: Tue Jul 14, 2020 11:52 am    Post subject: Reply with quote
OK...
K-Roll931
PostPosted: Tue Jul 14, 2020 1:35 pm    Post subject: Reply with quote
That's bizarre. I've replaced the filter three times on my own car and I've always done it as tight as I can by hand and maybe a little bit more. The best I can think of is something with the threads is wack, and something else is causing the filter to back off the threads for one reason or another...
'80 931 M471 - Dolomite Gray -> Monaco Blue
PostPosted: Tue Jul 14, 2020 1:43 pm    Post subject: Reply with quote
I've never had or even seen this happen to any other car..
Best idea I have so far is to put a hose clamp around the filter and wire it tight/still from the hose clamp to something..
It coming loose last time, it could have vibrated there long enough to wear the threads a bit, but it looked fine..
So far I think I'll be checking the OPRV and wiring it still with a hose clamp on it..
Bizarre indeed..
K-Roll931
PostPosted: Tue Jul 14, 2020 2:11 pm    Post subject: Reply with quote
I've got one more thought before turning in for the night. What if the oil filter isn't loose, but the center threaded portion is? There's a stud that the filter threads onto if I remember right? So you're tightening the filter but the stud is backing out over time?
peterld
PostPosted: Tue Jul 14, 2020 11:16 pm    Post subject: Reply with quote
+1. That has happened to me......luckily caught it.
80/81 932/8 ROW
TJC
PostPosted: Tue Jul 14, 2020 11:44 pm    Post subject: Reply with quote
Overtightening.
Read directions on filter.
Apply a light film of clean oil to filter gasket prior to installing and be sure filter base seating surface is clean.
Stuck/sticking oil pressure relief valve as mentioned.
Do you monitor your oil pressure while driving?
Are you using a high quality filter?
How long has this last filter been installed, time/mileage?
'95 BMW 318i/5 ..."Pearl"
'04 BMW X3..."Xander"
Still on the Prowl!
www.ttrs1.com
PostPosted: Wed Jul 15, 2020 2:20 am    Post subject: Reply with quote
Overtightening. - maybe
Apply a light film of clean oil to filter gasket prior to installing and be sure filter base seating surface is clean. -yes
Stuck/sticking oil pressure relief valve as mentioned. - will look
Do you monitor your oil pressure while driving? - no
Are you using a high quality filter? - yes/no happened with a mahl and a napa
How long has this last filter been installed, time/mileage? <1 year, couple k miles
Think I'll take the adapter thing off and give it a thorough inspection..
Not that I'm glad it happened to you, but kinda glad I'm not the only one..
winddude
PostPosted: Wed Jul 15, 2020 6:24 am    Post subject: Reply with quote
old gasket stuck to the block? but than normally you'll get a leak right away...
PostPosted: Fri Jul 17, 2020 10:44 am    Post subject: Reply with quote
Put a T-bolt clamp on it with a piece of plumbers tape down to the turbo oil return to keep it from backing off the threads ever again..
Same thing, just came loose enough to finally blow the o ring out of the filter..
Won't happen again like this now I don't imagine..
Rips again...
Only have like half my tools right now so I didn't tear into the filter adaptor..
PostPosted: Fri Jul 17, 2020 12:10 pm    Post subject: Reply with quote
Check your oil pressure relief valve before you blow something else.
poor-sche
PostPosted: Fri Jul 17, 2020 12:18 pm    Post subject: Reply with quote
Maybe the threaded union has damaged threads or it’s a little loose inside the filter housing? Looks like it’s replaceable.
PN. 059115721
PostPosted: Fri Jul 17, 2020 4:17 pm    Post subject: Reply with quote
It just now hit me that you are probably talking about the one by the oilpump and not the thermostat thing in the filter adapter..
Right?
PostPosted: Fri Jul 17, 2020 10:28 pm    Post subject: Reply with quote
Yes, your issue may be that it is stuck or clogged, thus allowing oil pressures higher than the oil filter gasket can withstand.
