MisterP931
Posted: Sat May 22, 2021 3:37 pm Post subject: 931 short shifter |
| Hi Guys is there any short shifter for the 931 on sale? |
Posted: Sat May 22, 2021 4:35 pm Post subject: |
You can cut and weld the existing shifter to change the pivot point distance to reduce the throw and retain existing gear knob. _________________ 1980 931 - forged pistons, Piper cam, K27/26 3257 6.10 hybrid turbo, 951 FMIC, custom intake, Mittelmotor dizzy & cam pulley, H&S exhaust, GAZ Gold, Fuch'ed, Quaife
SpreadTheTed
Posted: Tue Jun 01, 2021 9:09 am Post subject: |
| If it's a later Audi Transaxle a 944 short shifter will work. Not for the snailshell though |
Posted: Thu Jun 03, 2021 5:19 pm Post subject: |
| SpreadTheTed wrote: | | If it's a later Audi Transaxle a 944 short shifter will work. Not for the snailshell though |
The guy is in Germany and posted in turbo section. So one can assume its G31 and not Audi box? ....... RoW never had the Audi box _________________ 1980 931 - forged pistons, Piper cam, K27/26 3257 6.10 hybrid turbo, 951 FMIC, custom intake, Mittelmotor dizzy & cam pulley, H&S exhaust, GAZ Gold, Fuch'ed, Quaife
Gatornapper
Posted: Sun Oct 24, 2021 10:51 am Post subject: |
RSR -
Hmmm......the '80 931 uses a 911 tranny, same as in the 914's.
Would the cut/shorten/weld trick work on its shifter?
If so, I can pass it on to my many 914 friends too.
GN
| Carrera RSR wrote: | | You can cut and weld the existing shifter to change the pivot point distance to reduce the throw and retain existing gear knob. |
