Rafael
Posted: Mon Jan 27, 2003 3:57 am Post subject: about voltage regulator |
Has anybody make this to have more voltage output?
look at this and tell me if it´ll work. www.detomaso.nu/~thomast/alternator/
I´m going to do it the next week.
My car only gives 13,4 and when i put the lights on drops until 12,8 or so withdout tell when the radiator fun turns on 12,3.
I´ll try it.
wish me luck.  |
Posted: Mon Jan 27, 2003 9:21 am Post subject: |
the mod seems sound.
Before you do that it might be a good idea to fix the problems you have. I would suggest replacing the earth cable between the alternator and the block and connecting a second earth cable from the rear of the alternator to the chassis rail. Also check the earth cable from the block to the firewall, the cables from the alternator to the battery and clean up the earth "crown" under the dash above the fuse box and the connectors to it.
If after fixing the things that always cause a low charging voltage you still want more charging voltage then drop in a diode. _________________ 1979 924 (Gone to a better place)
Alex Roy
Joined: 03 Nov 2002 Posts: 694 Location: Springfield Oregon USA
Posted: Tue Jan 28, 2003 4:04 am Post subject: |
| This may be a really great mod for those car stereo heads out there too....I may just try this on my extra alternator. |
numbbers
Posted: Tue Jan 28, 2003 12:27 pm Post subject: |
There is a much simplier mod that achieves better results. Just replace the Bosch alternator with a Delco. _________________ 1980 924 Turbo |
Posted: Tue Jan 28, 2003 4:09 pm Post subject: |
I think a delco alt would be slightly more expensive than a $1 ($0.02 in quantity) diode. _________________ 1979 924 (Gone to a better place)
Rafael
Posted: Wed Jan 29, 2003 4:04 am Post subject: rafael |
I´ve made it today and works.
Now I´ve got 14,4 volt. at the battery.  |
