How to make the car run happily?
PopUpProject
PostPosted: Thu May 14, 2026 7:18 am    Post subject: How to make the car run happily? Reply with quote
Just trying my best to figure this out without total failure
Poppy the '82 924 Resurrection in Progress
PopUpProject
PostPosted: Thu May 14, 2026 12:48 pm    Post subject: Reply with quote
Trying this again since originally it posted blank
Hey guys, we are almost to the point where Poppy can go on her maiden voyage on actual roads!!!! However, I have a sneaking suspicion this car was tuned while she was full of vac leaks, had a non functional O2 sensor, and other chaos. The car ran well previously but it seems every time we fix a vac leak she gets pissy. We recently replaced the vac line that goes to the crankcase breather (honestly surprised the car ran as well as it did with as many leaks that line had) and now she is really mad under load. She idles pretty well I would say, but under load she is breaking up really bad. The rpm gauge isnt boucning like a misfire under load but the gas gauge does.
PopUpProject
PostPosted: Thu May 14, 2026 12:50 pm    Post subject: Reply with quote
I'm guessing this means there is a fueling problem? I am not totally sure what to do now because I am just barely figuring out how it even runs fuel in the first place. Has anyone had a similar issue or know what could be going on?
Here's a video: https://drive.google.com/file/d/1WJH8uo9hk0o7Ah9Bx5-D8-JNsnSQzjHd/view?usp=sharing
PostPosted: Thu May 14, 2026 8:52 pm    Post subject: Reply with quote
Can't see a video, check the link? I just see the same set of relay pics.
As for tuning... it's always back to first principles, check fuel pressures, settings, etc... but the misfire is curious, and if the fuel gauge is jumping around, that absolutely sounds like you have a general ground or other wiring problem (did you already clean the grounds under the dash?) that very easily can impact the motor running.
I wouldn't worry about the O2 sensor much, that's out of the loop for anything other than idle or light throttle conditions. Certainly not used for large throttle applications.
PopUpProject
PostPosted: Fri May 15, 2026 7:11 am    Post subject: Reply with quote
oops, my bad, the site decided to post my posts as blank so I was scrambling to fix it before I left for a conference. The link should be fixed now. I freshened up the ground on the right side of the dash near the glovebox, is there another on the drivers side? My O2 sensor was quite literally cut in half at the wire, so it definitely didn't work previously, but I do know these things are quite sensitive so I am trying to make sure I name all of the things we have done so far. Speaking of, we have also done spark plugs
PostPosted: Fri May 15, 2026 8:49 pm    Post subject: Reply with quote
Yes, there's a cluster of grounds to be cleaned off behind the fusebox - more or less on the underside of the windshield tray, inside the cabin. I find TarnX metal polish works really well on the brass terminals...
Can't really tell anything of note/weird from the video, TBH... sorry.
PopUpProject
PostPosted: Fri May 15, 2026 9:22 pm    Post subject: Reply with quote
TarnX has been my best friend, I'll have to go hunting in the rats nest with the toothbrush. Thanks Vaughan! And here's another video, maybe you can hear it breaking up better in this one. It shows the RPMs stay steady while breaking up, but I was dumb and didn't get the gas gauge going crazy
https://drive.google.com/file/d/1ZhSfncX5gTTddfjysQQ3klxpxN5jL-_O/view?usp=sharing
PostPosted: Sat May 16, 2026 2:27 am    Post subject: Reply with quote
OK yeah I can hear that much clearer now.
I'd definitely be chasing ignition side for that. And no, definitely not right.
I'm surprised to see the idle that high; have you tried working it down lower, or does it die? If you can't get it lower with adjusting the idle screw, that would scream more vacuum leaks.
I'd be inclined to see if it's one specific cylinder that's misfiring; best way to do this is to sequentially disconnect one plug wire at a time, with the motor running, and evaluate the rpm drop. When you get to one that doesn't change the rpm, you know that cylinder isn't doing much!
Another way if you were running a header is to use an IR temp gun on each cylinder and look for the cold one... not as useful with the stock original exhaust manifold though.
Then move plug wires and plugs, see if the problem moves with those... to rule them out as a problem.
You could also, if one cylinder and doesn't move with plug wires or plugs, look at the fuel injectors, maybe one is clogged? Have you already replaced them?
Still want to clean those grounds.
Worth also inspecting the rotor and cap for contamination - I've had that, deposits on the terminals inside the cap. Or maybe wiring to coil, coil itself...
PopUpProject
PostPosted: Sat May 16, 2026 5:56 am    Post subject: Reply with quote
We got her to idle around 900-1k and she sounds happy at idle around there. We also swapped the distributor cap and rotor (or as I call them, mr. spin spin and mr cap), we'll have to play swap the wire around to see if we can tell who is misfiring. Have not done injectors or spark plug wires yet, but new spark plug wires were the next thing on my list to acquire
PopUpProject
PostPosted: Wed May 20, 2026 10:27 pm    Post subject: Reply with quote
Update: the spark plug wires were CRUSTYYYY on the metal boots that go around the spark plugs. Did not realize they were that bad when we changed the plugs. That probably was not helping anything. The ground strap from the chassis to the bellhousing is also holding on by a thread. I discovered this a while ago and completely forgot about it because the oem strap I ordered from Pelican looked way different so I didn't think it would work. Turns out it will, but the bolts holding the current strap in are on there with like ugga dugga strength. I tried big bertha with no success, so I soaked it down with some deep creek and will try again.
I am hoping when we start her up she is much happier under load, otherwise I think the next step is trying to figure out the k-jet I have ordered the Probst bible off amazon and as long as amazon doesn't eat this package (like they did with my terminal covers) that will arrive on thursday.
I looked in the rats nest for the ground above the fuse box, but I cant see where it is with the rats nest as they are pretty well formed into place from being a rats nest over the years. Any chance someone has a picture? I believe I cleaned all my grounds besides that guy, behind both headlights, behind glovebox, in the trunk between the taillights, and the actual battery ground connection. Am I missing any?
PopUpProject
PostPosted: Thu May 21, 2026 10:50 am    Post subject: Reply with quote
MASSIVE UPDATE: WE WENT FOR A MAIDEN VOYAGE TONIGHT!!!!!!!!!!!
Got the new ground strap installed and fixed a blue/yellow wire at the back of the block.
She is still pissed under load and seems to fall flat on her face. It also seems the warmer she gets the worse it gets. The gas gauge is also still bouncing all over the place. However, the fans do kick on and the temp gauge works. Here is a folder from todays adventures: https://drive.google.com/drive/folders/1mysRYF2pDRUvO0YGsUJrV0ezKMnYENLs?usp=sharing
PostPosted: Fri Jun 12, 2026 11:59 pm    Post subject: What news? Reply with quote
It's been a while - any updates??
PopUpProject
PostPosted: Sat Jun 13, 2026 12:29 am    Post subject: Reply with quote
unfortunately not yet, she is currently in the parking lot at work while we try and locate a storage unit we can throw her into. Our buddy's wife booted us from his place so trying to find a place we can get her to to work on before we make things worse playing with stuff
Then basically the plan is to tear the whole thing apart (not really but probably a lot of it) fueling wise and start with a refresh of components. Rock Auto looks like they have Bosch injectors but I gotta also find a place to do lines nearby and save up for that because I don't trust them to not break when trying to pull the injectors.
Anywhere thats not the UK I can find the little weird dudes the injectors sit into? If I had to guess these are rubber and also probably barely holding on, PN 063 133 555
PostPosted: Sat Jun 13, 2026 3:50 am    Post subject: Reply with quote
Actually, they're plastic, and aren't a wear item on the non-Turbos. So I 100% advise leaving them alone unless you are removing them to go EFI (in which case it's needed).
The lines are actually pretty robust... I would be extremely surprised if they break.
PopUpProject
PostPosted: Wed Jun 17, 2026 6:15 am    Post subject: Reply with quote
Oh sweet, the images online looked like they were rubber so I had little hope for them, thanks Vaughan! My lines are the original lines and they look questionable, a lot of the black protective cover has cracked or started to crumble off so I'll have to replace them eventually for my own sanity I just hope they come off from the injectors easily
