My 924 Turbo, first track day of the year
Goto page Previous  1, 2, 3 ... 20, 21, 22
PostPosted: Thu Aug 14, 2025 5:48 am    Post subject: Reply with quote
Awesome track session guys!
Thanks for sharing!
safe
PostPosted: Thu Aug 14, 2025 4:57 pm    Post subject: Reply with quote
It's pretty interesting, transaxle vs rear engine, NA vs turbo. But similar era.
Cedric had the better laptime of us that day! 43.66 to mine 44.59, almost 1 second.
You know, it was my first time at that layout, my car really doesn't like going into 3rd and smaller tires (brand new though), ancient suspension...
Excuses are endless!
But I think I broke something in the rear suspension. I have a horrible creaking on the right hand side now. Haven't had the time to check it yet.
Lots of fun either way!
/Magnus, Stockholm Sweden
Porsche 931 -79
Porsche 911 -77, 3.2 Targa
Porsche 911 -69, 3.6, Coupe
PostPosted: Tue Jan 06, 2026 11:04 pm    Post subject: Reply with quote
This will get a separate post, but Im doing a little fun project with some calipers I bought cheaply on black friday, one of the very few calipers with the same hydraulic area as the std ones, which i need since i used front calipers with the same area as std. Didnt intent on changing the rears, im very happy with the brakes at the moment, but its fun to make adapters, so I did it anyway
PostPosted: Wed Jan 07, 2026 7:51 am    Post subject: Reply with quote
Also did some air box mods, summed upp in this thread:
https://www.924board.org/viewtopic.php?p=416848#416848
PostPosted: Thu Jun 11, 2026 6:49 am    Post subject: Reply with quote
Some photos from this winter, other than the wilwood rears. Found a cracked seat mount that needed welding, also fit a new OMP dual locking seat rail which fixed the very annoying slop of the original one, so much better.
Had a track day aswell to try everything out, hopefully some video coming out aswell. really fun to hammer it again, its really when the car really shines Im still adjusting to the brakes, the high friction pads I chose and stiffer calipers do take some adjusting to not lock up everywhere. After so many years it takes a while to readjust, but in the end of the day it started to work out really well, when i let them warm up before going hard, the bite and feel is very very good now! (DS3.12 front and EBC RP-X back). The GAZ golds are also working really well, very comfy for the road driving, and good control on track. Will put on my stiffer springs sometime, it needs it
Everything held up great, bolt got loose to the right camber adjustment which made camber very dymanic as seen on the videos afterwards (and on the pics below), Im going back to factory bolt there, have those on the left and they hold up just fine, much better designed.
https://www.instagram.com/p/DYXx-sBOprO/
3d Printed seal between IC and rad
Adjusted spacers in the rear, this might almost work
Erik and his supercharged 924 joined aswell
PostPosted: Wed Jun 17, 2026 1:10 am    Post subject: Reply with quote
Some video from the driving, including some very varying front camber, and laying down of some rubber on the track
https://youtu.be/cJkyhzB8NX4?si=oPVisDJnJQkKBY70
jacobroufa
PostPosted: Wed Jun 17, 2026 2:21 am    Post subject: Reply with quote
Looks like a lot of fun, aside from camber changing mid-turn!
1980 Porsche 931
1981 Porsche 924 Weissach
safe
PostPosted: Wed Jun 17, 2026 3:10 am    Post subject: Reply with quote
And if the camber changes, so does the toe!
Porsche 931 -79
Page 22 of 22
