GalironR
Posted: Wed Jun 17, 2026 2:14 pm Post subject: Finally got the head off. |
I finally got the head off the block I'm fairly sure its hosed. Attached are the images of the head and the cylinders. Some of the images are with the head straight off the red ones must be trans fluid the prior owner poured into them 2 had the red fluid and a gray/brownish goo under it 1 was entirely dry another had a little anti freeze in it I assume it for in when I was first messing with the head trying to get it free. Even with the head off I get zero movement with a breaker bar so I'm assuming the piston rod or the crank is hosed as well. The head doesnt look to bad and the pistons I can see seem ok again from what I can see. So how screwed do you all think this engine is lol
[/list] |
