CMXXXI
Posted: Thu Jul 03, 2003 5:27 am Post subject: G31 transmission repair - How To (Long Post) |
This is the second of a 3-part post concerning the repairs I did on the 5-speed snailshell transmission. The first part deals with removing the transmission, the third part deals with reinstalling the gearbox (plan on doing that this weekend).
This link will take you to a “photo essay” of the work:
http://209.205.173.209/~camaro/gallery/album05
I did not (but should have) reference in the text below, the photos that go along with each step. Not knowing what I might do with the photos (move, rearrange, remove, etc) I thought it was just too much trouble.
In doing my research before getting started, I discovered some confusing information in the manuals. I have the factory manuals for both the “base model” and the turbo, as well as the Haynes and Chilton’s manuals. Comparing procedures, line drawings and photographs I was able to “piece together” an almost-complete picture of what needed to be done and how. But, as with most work that you do for the first time, I discovered some “gotchas”. None of the manuals were very detailed in exactly what had to be done, a lot of steps were assumed. Also, the drawings and photos were a mix of transmission models, I had to be careful in interpreting the images and “relating” what was presented to what was actually seen on the car.
Special thanks goes out to “Endwrench”, “–Nick” and Alex Roy for their input. Their comments were helpful and greatly appreciated.
In doing the repairs I replaced the following parts:
First gear synchronizer band (931.302.301.02, e-Bay, Partwerks of Chicago, $99)
Second/Third gear synchronizer band (931.302.301.01, EuroWebParts.com, $45ea)
Transmission fill plug (111.301.127E, Dealership, $4)
Gasket, transmission to differential housing (477.301.191.A, Dealership, $3)
Input drive shaft seal (999.113.247.40, NAPA #NOS9706, $8)
Output seals [both] (999.113.183.40, EuroWebParts.com # J7041-24000, $7ea)
Shift-shaft seal (001.301.227, EuroWebParts.com # J1162-52304, $2)
Shift-rod coupling bushings (911.424.223.90, PelicanParts.com # C-424-223-90, $16/pr)
Shift guide rod rear anchor (477.711.176A, EuroWebParts # J1079-40253, $39)
(I wrote this in Word, and all my tabs and page layout got lost, sorry. I put a pair of dashes [--] in front of each line that was indented which made for easier reading...)
Transmission disassembly:
This is going to be some messy, slippery work. Have lots of rags and some “quick dry” or clean kitty litter handy to absorb any spills. I also recommend that you have a supply of plastic containers and/or Zip-lock bags to put pieces in so you don’t lose or get anything mixed up. They will also help to keep dirt off of things. There are several needle bearing assemblies involved, and you need to ensure you don’t loose any parts or get them mixed up. All the bearings need to go back with the same gears, oriented in the same way they came out.
I recommend you have a clipboard, paper and pencil handy and make notes of how things looked when you took them apart. I marked the gears and bearings with a magic marker as I took things apart so I could reassemble everything exactly the same way it came apart. The gears and bearings may have markings on them to help you remember their orientation.
To perform these repairs you’ll need: 8mm, 17mm hex head (Allen type) sockets, 13mm, 16mm, 18mm, standard sockets, 22mm, 36mm deep-well sockets, some extensions, ratchet handle, 13mm combination wrench, some decent flat-headed punches, wood block, hammer, gear puller, retaining ring pliers, tweezers, anaerobic gasket sealant.
--Put the transmission on a suitable engine or transmission stand of some sort. I don’t have either, so I improvised by using a Black & Decker WorkMate. By spreading the tabletop the transmission was cradled in the gap pretty nicely. At other times I stood it up on its tail end and that worked a little better. I had to move it around and shift it to access various parts, so the table wasn’t the ideal surface, but it is what I have. The transmission is heavy (approx 100lbs) and un-wieldy so be careful not to drop it.
--Drain the unit by unscrewing the 17mm hex drain plug on the bottom of the differential housing. As you separate the cases additional oil will drain out, so it is a good idea to leave a catch basin of some sort under it even after you drain it through the main drain hole.
--Remove the coupling that mated the transmission to the car’s drive shaft by rotating the input shaft until the remaining 8mm hex (Allen type) bolt is accessible through the cut-out in the front housing and taking the bolt all the way out. There is a groove in the input shaft that the bolt goes in, and unless the bolt is completely removed, the coupling cannot slide off the shaft. Make a note of how far back on the shaft this coupling is, so on reassembly you can duplicate its position.
--Remove the 13mm bolts holding the front casing to the central section of the assembly. After all the bolts are off, make sure you are ready to catch some oil that is going to come out when you separate the sections.
--Using a small block of wood and hammer, gently tap on the edges of the backside of the front section to break the seal between the front and center sections of the assembly.
--There is a thrust washer on the end of the shaft holding the double gear, and it may fall off its shaft as you separate the sections. If you hear something fall inside the case, that is what it is, and as you pull the sections apart, don’t lose the washer.
--Pull the front casing off of the shafts. If the thrust washer did not fall off the double gear shaft, take it off now so it doesn’t fall off unexpectedly. Put the washer in a bag or container.
--Put a rag in the four oil passageways so parts or junk can’t fall down inside the transmission (This is Gotcha #1).
There are three shift shafts that are controlled by the main shift shaft that protrudes out of the transmission case (and attaches to the shift rod running to the gear selector): Reverse and 1st go to the fork in this outer section. The notch where the selector “tang” goes has a spring-loaded “lockout”. First is engaged by pushing the selector tang into the lockout then pushing the shift shaft into the case. There is a center “neutral” position, and reverse is engaged by pulling the shift shaft out. (Gotcha #2)The shift shaft, shift fork and shift sleeve can come off (beyond reverse) if pulled too hard – don’t pull it off yet.
The center shift shaft engages 2nd and 3rd gears and the outermost engages 4th and 5th. The lower number gear is engaged by pulling the shaft out, the higher gear by pushing it in. All the shafts will “stop” in-gear or in the neutral position because of a spring-loaded detent.
--Engage 1st and 5th gears: Push the outer shift shaft all the way in (5th). Grasp the shift fork for the 1st/reverse gear and push it in to engage the sleeve on the large first gear. This should lock up the transmission so neither the input shaft or pinion will rotate.
--With one of your punches or a very small chisel, gently “un-punch” the lock tab of the collar nut on the pinion shaft.
--Remove the pinion shaft collar nut with a 36mm deep-well socket.
--Remove the 17mm bolt on the side of the transmission housing that retains a detent and spring that engages with the 1st gear shift fork shaft. Remove the spring and detent, and put them in a container or bag. There will be another of these, so remember which spring & detent goes where. (Gotcha #3) If you don’t remove the detent and spring, you risk having them fall back into the depths of the transmission on re-assembly. Put the cap bolt back in the hole to keep dirt out and so it isn’t misplaced.
--Unscrew the backup light switch (22mm) and with tweezers extract the pin at the bottom of the hole. (Gotcha #4) This pin will block the shift shaft hole on reassembly if it isn’t removed.
--Gently but firmly pull forward on the 1st gear selector fork/shaft and shift sleeve until it comes completely out. What you will be doing is moving the selector sleeve out, off of 1st gear at the same time as you pull out the fork and shaft. There is no need to drive out the roll pins connecting the fork to the shaft.
--Pull off the sleeve if the fork disengaged before it slid completely off the guide.
--Pull off the sleeve guide.
--Remove the shift selector (that shaft with a foot on it that engages either of the three shift shafts).
--Gently pull the entire first gear assembly off the pinion. The synchronizer parts are kept in place by a retaining ring/clip, so don’t worry about losing them
--Be careful to keep everything together. There is a thrust washer, and the gear itself along with the internal synchronizer parts. Between the gear and the shaft there is a sleeve and a set of caged needle bearings. Make a note of how these parts fit in relation to one another and put them in a container or bag.
--Remove the double gear idler gear. Be careful to keep the parts in order as they slide off the shaft. You removed the outer thrust washer earlier, now take off the gear, a washer-type needle bearing and another washer. Between the gear and the shaft are a caged needle bearing, a spacer and another caged needle bearing set. Don’t lose any of the needle bearings and keep everything straight so they can be replaced in the same order with the same orientation.
--Pull out the 2nd-3rd shift shaft until 2nd gear is engaged
--Drive out the roll pins that hold the 2nd-3rd selector yolk to the shaft and remove the yolk.
This completes the strip-down of the front section of the transmission
--Unbolt the 13mm nuts and one bolt holding the center section to the differential housing.
--Position a drip pan to catch the oil that will drip out when you separate the two sections.
--Using a small block of wood and hammer, gently tap on the edges of the backside of the center section to break the seal between the center section and the differential housing. There is a paper gasket between the sections, and depending on what kind of sealant was used on the gasket, it may be difficult to separate.
--Pull off the center section case.
--Put a rag in the oil passageways so stuff can’t fall down inside the differential. (Gotcha #5)
--I was never able to remove the fill plug in this center section, so at this point I drilled out the plug and replaced it.
--Drive out the roll pins holding the 2nd – 3rd gear selector fork on its shaft. Pull out the shaft then remove the fork.
To replace the 2nd – 3rd gear synchronizers, you have to remove the pressed-on outermost bearing. The bearing is the only part pressed on that has to be removed to do the 2nd/3rd gear synchronizers. The factory manual says to remove the entire pinion assembly at this point and press everything off. I don’t have a hydraulic press, and I didn’t want to remove the entire pinion and/or main shaft from the housing because of alignment issues during reassembly. So, I used a gear puller.
--Push the 2nd – 3rd gear selector sleeve rearward onto 3rd gear.
--Measure the space between the second gear and the thrust washer between it and the outer bearing. Get a “go/no-go measurement: mine was 0.012” / 0.013”
--Measure the distance between the outside of the outer bearing, and some identifiable part of the pinion shaft. On reassembly you need to try and match these values.
--Assemble an appropriately size gear puller, and have it grab under 2nd gear, between the gear and the shift sleeve. Grip the gear itself, not the row of “dog teeth”. I placed some thin brass shims on the gear-puller jaws to ensure that the puller didn’t damage the gear. The 2nd gear is free spinning, but what you want to do is to pull on it to remove the outer bearing. The washer between the two will evenly distribute the force and remove it. (Gotcha #6) ONLY PULL THE GEAR UP FAR ENOUGH SO YOU CAN GRAB UNDER THE WASHER. PULLING THE GEAR TOO FAR WILL CAUSE THE GEAR TO DAMAGE THE MAINSHAFT END BEARING.
--Reposition the gear puller under the washer and finish pulling off the bearing.
--Remove the 2nd gear, taking care to not lose any of the synchronizer parts. They are not held in place by anything. There is a synchronizer band, a thrust block, a stop and a locking band. I found it easiest to extract the needle bearing and sleeve, then remove the gear because the gear will hit the mainshaft bearing if you try and remove it with the bearing and sleeve in place. On re-assembly, positioning the gear first and then inserting the bearing & sleeve is the way to go.
--Make a note of how the caged needle bearing and second gear fit, and put all the parts you are removing into a container or bag so you don’t lose those needle bearings, and you keep the right bearings with the right gears, oriented in the right direction.
--Remove the selector sleeve off of 3rd gear and remove it.
--Remove 3rd gear and the parts that come with it. Again, the synchronizer parts can fall off, and watch out for those needle bearings, don’t lose them and keep them along with the gear in a separate container or bag so you don’t mix them up with the others.
This completes the strip-down I did of the pinion. If the 4th or 5th gears, or the last bearing on the pinion need replacing, they may need to be pressed off instead of using a gear puller because of the long reach. Also, removing the clamp plate to separate the pinion from the differential housing will cause the current alignment of the pinion and ring gear to change when you reassemble things. To properly align everything, several measurements using a backlash and run-out dial will be needed. If you don’t have them or the expertise to use them, I would not recommend doing this work yourself.
Gear synchronizer replacement:
Assembling 2nd and 3rd gears’ synchronizer assemblies is a piece of cake, and are the same. The “stop” goes into the notch cut into the locking band. The thrust block goes into the open space in the locking band. The synchronizer band fits inside the row of “dog teeth”, with its open section surrounding the thrust block. The synchronizer and locking bands are like concentric “C’s” with the thrust block in the opening. Coat everything with oil and put it together in the proper order
The 1st gear assembly is held in place by a wide retaining ring. This ring is VERY strong and is difficult to remove, and harder to replace. I recommend covering your sturdy worktable with heavy cloth or several layers of newspaper, and (Gotcha #7) wearing gloves to help prevent hurting your hands if something slips. Remove the retaining ring with a pair of retaining ring pliers by opening the ring far enough to get it out of the groove it locks in.
Once the ring is off, assembling it is similar to the 2nd/3rd gear assemblies. The only difference is (this is important!!) that, if the stop block is at 6:00, the opening on the lock ring is at, like, 1:00 or 2:00 in relation to the stop, whereas on the 2nd/3rd gear assemblies, the opening is directly opposite the stop.
To get the retaining ring back on is difficult. To spread the ring far enough and to get it to “catch” under the locking lip on the gear takes some hand strength and persistence. I ended up clamping the assembled gear to the table with a wooden Jorgenson clamp to keep the ring from “buckling” when it was opened far enough to go over the lip. Once I got it started (while still clamped down) I drove it the rest of the way around with a small brass drift. The synchronizing ring will want to come un-seated as you man-handle the thing, and if unseated, the retaining ring can’t engage the lip. Once you see it, this description will make more sense.
Once the retaining band/clip is back on, make double sure it has engaged the inset ring above the synchro ring, and then rotate the retaining ring so it’s split is not over the stop or thrust block. Mine was assembled so the retaining ring opening was like at 4:00 or 5:00.
Transmission re-assembly notes:
Reassembly is pretty much in just the opposite sequence of disassembly, but a couple of pointers are:
I reversed the 2nd/3rd gear selector sleeve when putting things back together. The 2nd gear side had more rounded splines than the 3rd gear side. (see the last few photos in the photo essay) Since I was having noticeable grinding in 2nd, I think that maybe reversing the sleeve will help out. This was a gamble, I don’t know if it will pay off.
When putting the2nd gear back on the pinion shaft, put the gear in place first, engage it’s teeth on the mainshaft, then drop in the needle bearing and sleeve, otherwise the gear will hit the roller bearing on the end of the mainshaft.
You will have to tap the pinion shaft end bearing back onto the pinion if you removed it using a gear puller like I did. Do this gently and equally all the way around the bearing to prevent it from galling, and be sure and drive the collar of the bearing, not the cage holding the roller bearings. I took a wooden Jorgenson clamp and stood it on end and used it like a double-footed punch to re-seat the bearing. Duplicate the spacing between the bearing and the thrust washer like it was when you pulled off the bearing.
Don’t put the detents or their springs back in place until everything is assembled. I say this because the detents make it difficult to manipulate the shifting motions you will have to do when putting things back together. If the detents are in place and you accidentally pull one of the shafts out, you can lose the detent inside the transmission or differential (Gotcha #3) and you will have to open it back up to retrieve it (or at best, turn the thing up-side-down and hope the detent comes out one of the oil passages). This happened to me, and it wasn’t fun.
When reassembling the 2nd/3rd gear shift fork and shaft, remember to engage the fork in the shift sleeve, and then push the shaft through the fork. You’ll have trouble reassembling things if you put the fork on the shaft first, and then try and put the shaft in place. Brace the fork and shaft as you drive the roll pins back into place so you don’t strain the shaft or its mounting holes as you hammer the pins back in place. An alternative method to re-seat the roll pins is to use a “C clamp” and press them back in place.
Clean the flanges and replace the gasket between the differential housing and the center section. Dress the gasket properly and seal it with an anaerobic flange sealant like Loctite 573.
Also brace the yolk on the 2nd/3rd shift selector yolk as you drive the roll pins back into place so you don’t strain the shaft or its mounting holes as you hammer the pins back in place. An alternative method to re-seat the roll pins is to use a “C clamp” and press them back in place.
There is another detent that goes sideways between the shaft holes for the 1st/reverse and 2nd/3rd selector shafts. This detent can block either of the holes, and you have to make sure it is in between the holes on reassembly (Gotcha #8) or you can’t get the shafts in all the way.
Make sure to remove the backup switch activation pin before reinstalling the 1st gear selector fork shaft (Gotcha #4).
Just like the 2nd/3rd gear detent, make sure you don’t put the 1st/reverse detent in place until everything is reassembled. The fork & shaft are not anchored, and if pulled out too far, the detent can fall back inside the central housing (Gotcha #3).
Clean the flanges and seal the front transmission housing with an anaerobic flange sealant like Loctite 573.
I recommend replacing the shift shaft coupling bushings, the shift guide rod anchor and output seals on the differential casing while the transmission is out, and to also replace the drive shaft input seal and main shift shaft seal. All together the seals only cost about $25 and it’s good insurance. The bushings and rod anchor run about $45-$50. You sure don’t want to pull the transmission again just to replace any one of these items. _________________ '79 Eurospec 931 |
Silverarrow
Posted: Tue Jul 15, 2003 5:29 pm Post subject: Tranny rebuild |
Mercy! You put a lot of work into posting the details of this endevour. I commend your effort. Thanks for the hard work it took to post this and the detailed photos on your site. It will make it easier for others to do ing the future. This is like restoring old airplanes. If we don't do it, those in the future will never know cars like this existed. I love my 931. Some smart fella designed it and made it darn near rust proof. Near perfect weight distribution and sweet handling. They're so nice i own two of 'em.
Well I've bubbled over long enough. _________________ 1977 924 NA no sunroof
1980 931 With a sunroof
I could be crazy, Oh yes I could! |
-nick
Posted: Wed Jul 16, 2003 1:47 am Post subject: |
hey CMXXXI -
can you tell us what size gear puller you picked up to pull the pressed bearing off the mainshaft? and once again, this is a great post! i can't believe more folks haven't commended you on it.
-nick |
CMXXXI
Posted: Wed Jul 16, 2003 4:02 am Post subject: |
When I did the work, I lost two photos (stupid mistake), both were of 2nd gear being pulled. What I had to do in order to reach down far enough was to make my own "arms" for the gear puller. The puller is made like a hub with the screw going down the middle, with short arms attaching to the actual jaws of the puller.
What I did was to take some 1" bar stock I have laying around for welding projects, and I cut 6" pieces to replace the 2" "arms" that came on the original puller. The 6" reach and the amount of pull provided by the screw was enough to pull the gear far enough off to use the original "arms" to grab the washer under the bearing.
I can't stress it enough, you can't pull the bearing off all the way with the gear. The gear will make contact with the mainshaft bearing. Only pull the gear/washer/bearing up enough to grab under the thrust washer that is between the gear and the bearing, then pull on the thrust washer to remove the bearing. What I forgot to say in my write-up about removing the 2nd gear is, that once the bearing is off, you should "extract" the needle bearing and the sleeve from between the shaft and the gear in order to give you enough radial movement to take the gear off the shaft.
I'll see about making a photo of the rig this evening and posting tonight or tomorrow. _________________ '79 Eurospec 931 |
Joined: 29 Jul 2001 Posts: 9115 Location: Royal Oak, MI, USA
Posted: Wed Jul 16, 2003 11:44 pm Post subject: |
Can I archive this on 924.org Tech Section? I was planning to do my own such article with the '79 924 trans, but I bailed on the rebuild when I got in there (as too many parts were too far gone) and swapped to an Audi trans instead.
Let me know... _________________ Vaughan Scott
CMXXXI
Posted: Thu Jul 17, 2003 12:58 am Post subject: |
Here's some photos of the gear puller I used. It was a "standard" 3-arm puller I bought at AutoZone. I cut 6" lengths of 1" barstock and drilled holes .5" from the ends and off-set the holes to make sure they fit up next to the hub (otherwise the ends would have to be tapered or ground). Depending on the jaw length and the screw length of your particular puller, a 4" arm probably would work also.
Click the photos for larger images.
The original short puller with 2" arms
Puller with 6" arms
Puller dis-assembled showing all parts of long and short _________________ '79 Eurospec 931 |
CMXXXI
Posted: Thu Jul 17, 2003 1:07 am Post subject: |
Vaughan, I'd be happy to have you include my step-by-step and/or photos in the tech section. If you'd like, I'll e-mail you the original Word document if you'd prefer so you can format it better using HTML (It would sure make it easier to read). Or, I can put the document and photos on a CD and mail it to you if you think that would be a better way to go. _________________ '79 Eurospec 931 |
Posted: Thu Jul 17, 2003 1:15 am Post subject: |
Emailing the Word document would be excellent, thanks! _________________ Vaughan Scott
Posted: Sat Aug 30, 2003 3:51 am Post subject: |
Nice touch with the licence palte & Well done on
documenting your work,
I copied your text and pictures just in case something happens
also I lightened up all the dark pics. _________________ 1979 porsche 924 Na
Have u ever driven a turbo. |
-nick
Posted: Sat Aug 30, 2003 4:11 am Post subject: |
on the topic of that grear puller-
i used autozone's tool exchange thing and they had large and small puller. the large one worked fine and there was no need to lengthen the puller arms. it made the process a little less time consuming.
-nick |
Posted: Sat Aug 30, 2003 6:52 am Post subject: |
Im suspecting this is what I should do this winter
and why not..will these synchros fit my o16z snailshell
I could check the part numbers though thought Idjust ask.
First gear synchronizer band (931.302.301.02, )
Second/Third gear synchronizer band (931.302.301.01, ) _________________ 1979 porsche 924 Na
CMXXXI
Posted: Wed Sep 03, 2003 3:47 am Post subject: |
Joe, the 931 synchro bands I think will be different between the G31 (turbo) gearbox and the 016/Y and /Z (non turbo) snailshells. The shaft size is different, and I'm going to guess that the other dimensions of the gears will also differ. I did a quick peek at PET and only saw the "931" prefix number on G31 internals. I strongly suggest you get the serial number off the bottom of the gearcase to confirm it's series then study the PET part number references to ensure you get the right parts. _________________ '79 Eurospec 931 |
leadfoot
Posted: Wed Dec 17, 2014 3:55 pm Post subject: |
FYI the below 928 dog tooth ring can be used for 2nd and 3rd gears in the G31
the only difference is the 924 part has a missing tooth on the inside face this part has all the teeth
928.302.242.00
carbon fiber GT mish mash
