oil pump pulley diameter ? 78 924
augidog
PostPosted: Tue Jan 27, 2004 1:43 pm    Post subject: oil pump pulley diameter ? 78 924 Reply with quote
Does anyone have the oil pump pulley out of the car for an actual measurement of the circumference ?
I need it to make some accurate timing marks for distributor curving.
I'm referring to the very inside oil pump pulley diameter at the crank.
I'll post my marks, measurements and the formula once I get it.
Thanks
Mikri184
PostPosted: Tue Jan 27, 2004 2:09 pm    Post subject: Pulley Reply with quote
I can do it for you tomorrow, which pulley would you like, the 3 groove the 2 groove or the single groove, I have all three out of cars. I will be running a single groove myself.
Life is to short to be looking for something?
CMXXXI
PostPosted: Wed Jan 28, 2004 5:16 am    Post subject: Reply with quote
Mikri - I think he's referring to the toothed pulley that the timing belt actually goes around.
'79 Eurospec 931
augidog
PostPosted: Wed Jan 28, 2004 10:53 am    Post subject: Reply with quote
No I am looking for the diameter of the most inner pulley closest to the crank with the TDC groove on it.
augidog
PostPosted: Thu Jan 29, 2004 11:37 am    Post subject: Reply with quote
I need the diameter of the one with the mark on it in this picture.
http://im1.shutterfly.com/procserv/47b3d700b3127cce8e91036f41720000001610
welder
PostPosted: Sun Feb 01, 2004 8:55 am    Post subject: Reply with quote
Ok,augidog, I just happen to have my motor in my living room, the outside diameter is 6 inches; the inside diameter is 5 inches as best as you can measure. I actually have the same pulley and can measure the small inside one if you need to. That one actually can increase low end acceleration, I'm not sure to what degree but I got that tidbit from Alex Roy. I know thats an old muscle car performance trick. If you need the circumfrence it's, diameter X 3.14 .
I have a 78 n\a currently under restoration.
augidog
PostPosted: Mon Feb 02, 2004 12:09 pm    Post subject: Reply with quote
Thanks to all.
timing marks for curving and full advance testing as follows.
5"1/4 straight across
1 degree =.045
2=.091
3=.13 =1/8inch
4=.18
5=.225
6=.27 = 1/4
7=.31
8=.36
9=.40 =3/8
10=.45
11=.49 =1/2
12=.54
13=.58
14=.63 =5/8
15=.67
16=.72
17=.76 =3/4
18=.81
19=.85
20=.90 =7/8
21=.94
22=.99 =1"
23=1.03
24=1.08
25=1.12
26=1.17 =1 1/8
27=1.21
28=1.26 = 1 1/4
29=1.30
30=1.35
31=1.39 =1 3/8
32=1.44
33=1.48 =1 1/2
34=1.53
35=1.57
36=1.62
37=1.66
38=1.72
39=1.75 = 1 3/4
40=1.8
