Marsh Guest
Posted: Tue Jan 22, 2002 4:50 pm Post subject: |
You see, my S' motor trashed before that paroxysm called Christmas and I've yet to find a replacement. No, that's not quite correct. There's a 944 local motor (I mentioned this to DWAK) available but while I know the bolts and nuts will fit, I'm unsure of the bits and ends.
You see, I was told by a Pelican guy that not just any 944 motor will fit in an S.
Brother S men, I need your help. The 924 guys are great, wonderful in fact but they don't understand S
Marsh |
Joined: 29 Jul 2001 Posts: 9117 Location: Royal Oak, MI, USA
Posted: Tue Jan 22, 2002 11:00 pm Post subject: |
Hmmm... perhaps there might be slight differences, but I think they'd bolt in... Porsche didn't change that much, not if they didn't have to. However, words of caution, I haven't messed with the engine of a 924S or 944... only suspension stuff...
_________________ Vaughan Scott
Zuffen
Joined: 31 Jul 2001 Posts: 1427 Location: Owasso, Oklahoma 74055
Posted: Wed Jan 23, 2002 2:25 am Post subject: |
Identical except for engine mapping, the S is detuned as not to woop ass on the 944 which is big and fat and slow.
Email me and I'll hook you up with a guy who knows all the details as he has done the swaps.
bob
_________________ Bob Dodd - 924turbo@cox.net
931 1982, 944 1982 euro, 924S 1988SE, 93 968 tip 06 Silver Cayenne S, 06 Black Cayenne S
I have Way too many cars, parts for the 931,944 and 951 |
eturbo924 Guest
Posted: Sat Jan 26, 2002 2:52 am Post subject: |
Posted this on the other section, but wanted to make sure you saw it.
I can get you a 924S motor with 53K miles on it for very reasonable amount.
Send me an e-mail and I can fill you in.
Eric
Eric.Lynch@itt.com |
afenn Guest
Posted: Mon Jan 28, 2002 12:37 am Post subject: |
Marsh
If you still can't find one we could work out a deal. I have an 87 motor out of a 924s with 101000 miles on it. It ran really strong but needs front seals behind the timing cover. It has new belts, pulleys and a new water pump on it. The only problem would be shipping costs. I could let the motor go for $800 min to help off set the cost of shipping. I'm in Enfield CT if you wanted to double check shipping. I believe it's going to be somewhere around $400 - $500. |
Zuffen
Posted: Tue Feb 05, 2002 3:09 am Post subject: |
Shipping with Forward Air will be around 350, please check. You have to crate and deliver to dock as well as pick up.
I.E.
from Tulsa to NYC was 200 bucks for a 600lb 912 engine and parts
afenn Guest
Posted: Tue Feb 05, 2002 1:27 pm Post subject: |
| Quote: |
I.E.
Thanks,
This motor isn't that heavy and I have no problem bringing it to the dock. Do they charge more on weight than size? Do you remember if you had to do anything special to the motor because of the fluids in it?
Andrew
[ This Message was edited by: afenn on 2002-02-05 14:27 ] |
wdb Guest
Posted: Tue Feb 05, 2002 7:22 pm Post subject: |
| if fluids leaking is a problem,a few old pillow cases with kitty liter in them will absorb any leaks and keep the kitty litter from making a mess and getting into the motor |
Zuffen
Posted: Wed Feb 06, 2002 11:05 am Post subject: |
no oil leaks or spillage.
No fuel period.
Must be on a solid skid/pallet with a bottom so nothing falls out and must be built to be stacked. It won't cost too much as you can ususally get free pallets by looking around, and check you discount lumber store for 2X4 and plywood.
Build a strong enough box and you might be able to reuse it. SO screw the lid on versus nailing.
They charge by size and wieght so make the only as big you need.
There is some kinda of size to wieght ratio where it really doens;t matter though so you might call your local hub adn find out.
Marsh Guest
Posted: Wed Feb 06, 2002 4:20 pm Post subject: |
To: Eric Lynch
To: Bob Dodd
My server/host/god knows what appears to be ####. I am not able to write to either of yo without my missive returning marked undeliverable.
Eric: What are the costs and conditions of the 924S and 944 short blocks?
Bob: Yes, I'd like to talk with someone who has put a 944 motor in a 924S
Thanks to you both.
Marsh |
eturbo924 Guest
Posted: Thu Feb 07, 2002 6:45 am Post subject: |
Short block 924S is in good condition. He is removing the head this week. So if you are interested in the short block for $450 let me know. Again it only has 53K miles on it and should be perfect.
Eric
Eric.Lynch@itt.com or
Eturbo924@yahoo.com |
