My Project Thread Fall 2010-Spring 2011
Goto page Previous  1, 2, 3 ... , 17, 18, 19  Next
flosho
PostPosted: Sun Jul 07, 2013 6:20 am    Post subject: Reply with quote
Cédric wrote:
Put up some under bonnet insulation, mine was quite thick, that removed alot of vavle train noise. Pretty impossible to get rid of on these cars, even with perfectly adjusted valves
Perhaps I should Dynamat my hood? or some other similar rattle reducer that the sound comp folks use... Wonder if that stuff can withstand the heat tho.
Would painting my valve cover help at all?
[This Space For Rent]
PostPosted: Sun Jul 07, 2013 6:23 am    Post subject: Reply with quote
I used this kind:
http://www.biltema.se/ProductImages/36/large/36-9214_l.jpg
Very lightweight and efficient. But over the turbo area the glue starts to give up, so might have to do something about that ...Should be something similar but higher quiality.
flosho
PostPosted: Mon Jul 08, 2013 7:53 am    Post subject: Reply with quote
Well, that might be on the back burner. My car wont go into reverse and 1st-3rd are much harder to get the shift lever into gear... haven't looked into it any further.
flosho
PostPosted: Thu Jul 11, 2013 5:59 am    Post subject: Reply with quote
Did some more poking around...
Car moves forward and back just fine, although I still can't get the car into Reverse while running.
1st, 2nd, 5th are really notching/hard to shift into. 3rd and 4th are a little easier, but if feels like I am "forcing" it into gear.
No grinds into any of the other gears except reverse.
I tried adjusting the clutch pedal back and forth and that did very little.
I tried to inspect the shift linkage on top of the transaxle, but I don't really know what I am looking for, they seem old and original. Probably worn down.
The shift lever has always been pretty floppy, so I'm going to do the temp fix to that.
Maybe I'll try to bleed the clutch slave again tonight and see if that helps at all.
Seems as though something internal in the trans is messed up or my clutch which was just replaced is having an issue, likely installation induced... So this totally blows!
PostPosted: Thu Jul 11, 2013 7:20 am    Post subject: Reply with quote
'I tried to inspect the shift linkage on top of the transaxle, but I don't really know what I am looking for, they seem old and original. Probably worn down. '
Jason, I have plenty of spares here if you think it's linkage. I also have a spare 931 transmission if linkage replacement doesn't work. I got this tranny with a parts car, so have no clue if it's better than yours. However, I installed a similar tranny from another parts haul, and it works great. I'm hesitant to sell the spare tranny though, hard to find.
joewest
PostPosted: Thu Jul 11, 2013 11:23 am    Post subject: Reply with quote
'79 924 Supercharged / Track Prepared
'80 931 Daily Driver - Sold
"The number of posts in my profile may represent the number of times I have screwed something up...and admitted it here."
flosho
PostPosted: Thu Jul 11, 2013 11:40 am    Post subject: Reply with quote
Didn't want to hear / see that...
Time for a 951 LSD unit...
flosho
PostPosted: Fri Jul 12, 2013 12:51 am    Post subject: Reply with quote
How much play is acceptable in the shift linkage on top of the trans?
There is plenty of play but it doesn't seem like it would be causing this issue so suddenly.
I jacked the rear up and put it on stands... Put the car in gear and the tires began to spin... That means the clutch is dragging?
Probably the fricken pilot bearing...
Think maybe I'll just part it out... Time to move on. I've been wanting to purchase an M3 for a while this could be it. The quest for a high hp 931 just isn't in the cards for me.
Raceboy
PostPosted: Fri Jul 12, 2013 5:15 am    Post subject: Reply with quote
Heh, M3 is a dog, unless it's e30 one but those needs the same push powerwise as 931.
Compared to any Porsche, E36 and E46 M3 handling is like a boat, driven them all. You have to build them as well to make any sort of decent car of them.
'83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'90 944 S2 Cabriolet
'78 924 Carrera GT replica
'84 928 S, sold
'91 944 S2, sold
'82 924S/931 "Gulf", sold
'84 924, turbocharged, sold.
PostPosted: Fri Jul 12, 2013 5:54 am    Post subject: Reply with quote
I was waiting for you to pop it up for sale.
It will be sad to see you leave the comunity.
Do you remember...a few years ago our talk about EFI vs CIS?...well, lets say socially, this is what "going EFI" does for you...and i'm not trying to be evil or anything..but its reality...you wanna go EFI..then you want another turbo..then manifolds then new injectors then pumps then bla bla bla bla...and its neverending.
Before you know it..you've taken out too much of the car you loved...and you have to sell it/part it....all this while for a few years you kept the car in storage and piled money into it without actually enjoying what it was made for...driving. For what its worth, i think you should have kept CIS and just enjoy it all these years, instead of trying to make e big hp monster out of it.
good luck with the sale, I hope it goes to a good home.
flosho
PostPosted: Fri Jul 12, 2013 6:09 am    Post subject: Reply with quote
Sure, but they sound great, look incredible, and I can enjoy the luxury every day, auto-x or take it to a track day and still commute all with one car. Plus it will have a warranty. My wife drove the 931 all last summer and I've been driving it plenty this spring and summer but this is it.
I work for a dealership so I will likely buy one at auction for wholesale price. E30 M3 would be sweet but it's old and they are expensive.
We have an '03 SMG at the place now and I really like it. It's a good all around car for me. Trust me, I wanted to have a 931 that would spank an M3, M5 or just about anything else short of a z06 but I doubt it's gonna happen anymore...
Arvidw
PostPosted: Fri Jul 12, 2013 6:13 am    Post subject: Reply with quote
Don't stop now you are at 90% of the project. Stop working on it for a couple of weeks and give it some time.
About the clutch dragging. Did you use a brand new nice and shiny clutch plate? Mine was dragging because the leafsprings between the friction plates rusted in a bad storage and therefore the clutch thickness increased.
Porsche 924 2.0 Kompressor 136.1wHp @ 5650rpm / 201.9wNm @ 3900rpm (dyno @ dp-engineering.nl)
Raceboy
PostPosted: Fri Jul 12, 2013 1:46 pm    Post subject: Reply with quote
There is no car that is good in everything, even 924
I have a separate daily beater (Audi A8 ) and project cars are just what they are, project cars.
I wholly agree that it is demotivating finding something to fail after hard work but occasionally failing gearboxes are sort of reality with high hp cars.
I agree with Arwid, just take some time off the car and find a daily driver that offers something that your project car doesn't and you will be very pleased in the end. Also you will enjoy your Porsche much more later.
My project cars have been sitting for months sometimes, just other things that are more important have come to the top in priority list, then its time for Porsches again.
On that note, yesterday I started the Gulf after some "minor" changes only to discover a healthy oil leak near oil filter adapter. Didn't bother to check further, will do in weekend or something.
'67 911 2.4S hotrod
'84 928 S, sold
'91 944 S2, sold
joewest
PostPosted: Fri Jul 12, 2013 2:03 pm    Post subject: Reply with quote
Project cars (and wrenching in general) are like women, I have come to find. You know you enjoy the work and can take the hits in order to enjoy all of that awesomeness, but sometimes you just want a change in freakin' scenery. The BMW world will bring it just as good as Porsche, but it's like blonde vs. brunette. Both fun as hell, and have their own special quarks...I'm a big fan of the total reboot. Love me an M3.
Damn....dropped the knowledge right there....
flosho
PostPosted: Sun Jun 11, 2023 9:18 am    Post subject: Reply with quote
Resurrection from a decade.
I did start the car today.
Page 18 of 19
