924 n/a to turbo
Goto page 1, 2, 3  Next
hawkman
PostPosted: Thu Feb 05, 2004 7:40 am    Post subject: 924 n/a to turbo Reply with quote
hi guys im new to this forum but i know all the down sides to making this modification. but i want to make my 1981 924 a turbo, i know that its more expensive and a lot of work but i have had the car for a few years and dont want to part it or sell it so i just want to give the ol girl some more go.... i was wondering if any one had a list or knew of a good way to start this project?
PostPosted: Thu Feb 05, 2004 7:56 am    Post subject: Reply with quote
well you can either get an after market kit (windblown?) and intall that, or you can get a 931 drive train, engine torque tube and tranny, you will of course need the entire 931 fuel setup as well, but what you could also do is keep the 924 NA and buy a second car a 931
3 928s,
hawkman
PostPosted: Thu Feb 05, 2004 8:45 am    Post subject: Reply with quote
yea i have heard of the Windblown and BAE kits but haven't been able to find them on the internet, i was also going to install a oil cooler and inner cooler as well as do a performance came stage 1, and finish my exhaust i wasn't looking for a large turbo just under 10 psi
PostPosted: Thu Feb 05, 2004 9:03 am    Post subject: Reply with quote
have you thought of a SC instead?
IMO they would be easier to install then a Turbo, and there is even a spot that would be easy to mount on
3 928s,
hawkman
PostPosted: Thu Feb 05, 2004 9:04 am    Post subject: Reply with quote
haven't really thought of a SC before because of the trent that goes along with a turbo, who would make a SC that would fit my car that would have a low enough boost that it wouldn't blow apart my head? and if i went that route what other parts would i need to fit with it?
PostPosted: Thu Feb 05, 2004 9:22 am    Post subject: Reply with quote
you could go with a Vortech SC that is the most efficent so I have heard but only really creates boost in the high up basically they are belt driven turbos,
as per a kit there isnt one, you would have to fab up your own mount and crank pully and works, however as per the BAE and Windblown kits, good luck finding 1, I have been here for over 2 years and have seen 3 BAE kits and only 1 windblown kit, and most of them were NOT for sale
3 928s,
hawkman
PostPosted: Thu Feb 05, 2004 9:32 am    Post subject: Reply with quote
if the SC only produces power towards the high end of the power band , i dont think that it would help, im looking for more of a midrange power boost, thats why i was looking towards the turbo..... instead of getting one of the kits if they are so hard to find, could i just get a used turbo and hardware off a 931 and use a manual boost controller to level down the boost
Alex Roy
PostPosted: Thu Feb 05, 2004 9:36 am    Post subject: Reply with quote
There was a BAE kit on ebay yesterday with a needs-to-be-rebuilt turbo.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=33742&item=2457978260
You just need to keep an eye out for used turbo kits and you'll come across one sometime. They seem to come up about every 6 months or so on ebay so they are pretty rare.
hawkman
PostPosted: Thu Feb 05, 2004 9:39 am    Post subject: Reply with quote
would it be worth investing in a turbo rebuild kit and rebuilding the faulty turbo or just scrap it and find a turbo somewhere else and use the kit and adapt it to the turbo
'81 924 n/a "The Baby" Modified!!!!!
'93 3000GT VR4 "Un-Touchable"
PostPosted: Thu Feb 05, 2004 10:00 am    Post subject: Reply with quote
the turbo from an 81 turbo makes peak at 3000 rpm which is the same as that SC, you could use a twin screw roots SC which is a really low spooling SC,
however also on the 931 parts it WONT WORK, the exhaust manifold will not allow you change the sparks plugs, but will also mess up the starter configuration and the oil filter as well
3 928s,
hawkman
PostPosted: Thu Feb 05, 2004 10:09 am    Post subject: Reply with quote
hhhmmm..... so its basicly find a turbo kit or go with a SC ...
PostPosted: Thu Feb 05, 2004 10:13 am    Post subject: Reply with quote
simply put YES,
3 928s,
hawkman
PostPosted: Thu Feb 05, 2004 10:16 am    Post subject: Reply with quote
i have another question about using the 931 , you said about the manifold blocking the spark plugs, well i was going to replace the manifold anyways and have a custome one made, would that make a difference? to the usage of the parts?
PostPosted: Thu Feb 05, 2004 11:00 am    Post subject: Reply with quote
if you want to go Turbo on the 924 and you are going to be fabbing up an aftermarket system why not use a more upto date turbo that has a better cooling system and ballbearings?
3 928s,
hawkman
PostPosted: Thu Feb 05, 2004 11:05 am    Post subject: Reply with quote
ok, just wasn't sure, if im correct the 931 used a kkk-27 or kkk-26 turbo ... i have heard a lot of good things about a T3 or T4 turbo but i believe they are very expensive
Page 1 of 3
