browning
Joined: 03 Feb 2004 Posts: 74 Location: salem arkansas
Posted: Sun Sep 05, 2004 9:06 am Post subject: coulpe ignition wiring questions. |
| ok i have never seen this car run....ever. it turns over easliy by hand.i went with a push button ignition. it tested it when i push the button i get power to the starter but nothing is happening. i have had the starter tested it is fine. is there a ground wire.is this going to be a wiring problem from the alt and starter?any help would be GREATLY APPRECIATED!!! |
Posted: Sun Sep 05, 2004 2:24 pm Post subject: |
| How did you wire the push putton to the starter? |
jpab924
Joined: 03 Nov 2002 Posts: 1538 Location: Crown pt. IN. 50 miles southeast of Chicago Ill.
Posted: Sun Sep 05, 2004 4:15 pm Post subject: |
| I`m in agreement with Paul. If it works right on the bench, it should work right with the push button if you have it wired right. |
browning
Posted: Sun Sep 05, 2004 10:01 pm Post subject: |
| i wired from consatant hot to the red black no50 threw my push button then i have a consant hot threw a toggle switch to solid black no15 for ignition. flip ignition things work push button nothing i'm getting power all the way to the starter could i have wired the starter and alternator wrong when i put them back in? |
