Engine Vibration Damper
ponchojuan
PostPosted: Thu Nov 11, 2004 4:39 am    Post subject: Engine Vibration Damper Reply with quote
So what is the consensus (is there ever one?) concerning this little shock absorber on the right rear side of the engine. Mine is hanging loose like a bad appendix.
Are these things really necessary and do they make a difference in vibration? Can you get the parts without hocking my first born?
Poncho
78 924 Vanilla
John Brown
PostPosted: Thu Nov 11, 2004 9:17 am    Post subject: Reply with quote
Years ago I managed to get one 'fairly' reasonable. It's so long ago that I do not remember how much. The list price is silly (or was, let us know and I'll update the data). See: http://users.adelphia.net/~johnbrown3/parts4.htm
Very likely your damper is still good - only the attachments are missing. In which case I do think it worth while purchasing the parts and re-connecting. As to the whole thing ... Pays your money and takes your choice.
John
80 931 - #931 44Cup
99 Escalade - tows track cars
PostPosted: Thu Nov 11, 2004 9:36 am    Post subject: Reply with quote
They want $276 for them here - http://www.pelicanparts.com/cgi-bin/ksearch/pel_search.cgi?command=DWsearch&description=477199501&I1.x=11&I1.y=6
"rubber buffers" are $2.79 each (4 reqd.) - http://www.pelicanparts.com/cgi-bin/ksearch/pel_search.cgi?command=DWsearch&description=92837516601&I1.x=11&I1.y=6
Vince Ponz
PostPosted: Fri Nov 12, 2004 12:25 am    Post subject: Reply with quote
Those prices are insane. I have never had one on my two 924s and never saw one on the two parts cars I bought. I say leave it off and if you have to buy motor mounts that are cheaper more often.
77.5 924 modified track car
79 931 Euro stock
88 924S SE
87 911 Targa stock
John Brown
PostPosted: Fri Nov 12, 2004 1:06 am    Post subject: Reply with quote
Vince is correct. Though, for some reason, the price of the right side motor mount expecially, seems to be going through the roof.
John
80 931 - #931 44Cup
Eturbo924
PostPosted: Fri Nov 12, 2004 1:33 am    Post subject: Reply with quote
I have one on my 1982 and one was on my 1980... but when I replaced the engine in the 1980 with an older block the mounts were not exactly the same so I did not hook it up. I did not note any difference in the engine vibration feel.
I think they are a waist of money but there has to be a reason Porsche wanted it there. I bet there is a specific rpm that it helps dampen the vibrations... but if you do not remain at that rpm for long periods you will never note it.
That would be my guess.
1992 968
2003 C4S
E-mail me for parts you need!
Drive Fast!
leadfoot
PostPosted: Sat Nov 13, 2004 2:47 pm    Post subject: Reply with quote
I don't have one... I don't have anywhere to mount one either...
Either this is because it is right hand drive and my steering column goes through the crossmember hole already, or possibly because it started life as an auto....
Leadfoot
Blas
PostPosted: Sun Nov 14, 2004 9:29 am    Post subject: Reply with quote
04/29/98
Purchased / Stock / Engine vibration damper - $62.42 (BGE 143-6DM) or (477 199 501) Shipping - $7.00, tax - $5.15
That's all I have.....
