Browar
Joined: 02 Jan 2003 Posts: 90 Location: Warsaw,Poland
Posted: Fri Nov 12, 2004 8:32 pm Post subject: ATF |
| Can I use ATF Dexron III fluid in 924S `87 for power steering? Workshop Manual says: Dexron II D. Which one should I use? I`m asking because second generation is almost unavaible ... |
Posted: Sat Nov 13, 2004 11:59 am Post subject: |
Dextron III is fully compatible with the previous Dextron II formula for use older cars. It will also work in cars that require Dextron. That's called "backwards compatibility".
I would not pour a can of Dextron II or Dextron I into a car that specifies Dextron III (not forward compatible). |
