headlights go crazy
jebe
PostPosted: Mon Nov 22, 2004 9:42 pm    Post subject: headlights go crazy Reply with quote
Who has the clue for this one;
First my headlights didn't come up at once. I had to wait and hope and after a few minutes they came up. Shortly after; nothing. Then I checked contact points at relay and connector but they looked fine, clean etc. Also twisting those a bit didn't help. Also the high beams (signal lights) didn't light up anymore when pulling the handle at the steering wheel. After I helped the headlights motor with the manual knob a bit the lights come up... but now go crazy when the light switch is in ''off'' position! They keep popping up and down and up and down untill I take the key out. With the light switch in ''on'' position they stay up normal. High beams; one works the other doesn't.
Anybody have clues? Appreciate it very much.
Jeroen (from the Netherlands)
924S, 1988
924guy
PostPosted: Mon Nov 22, 2004 11:01 pm    Post subject: Reply with quote
Call a priest to vanquish the evil spirits...
or..
check for obstructions, theyre probably hanging up someplace and cant seat correctly...theyll do this if a wire or other object gets in the path of the travel. its not always readily apparent, as things will flex or move into the way as theyre moving....
Eric
78 924
82 931 SE "smokey"
99' VehiCross
Y2K Honda Insight
Performance by Pasha
jebe
PostPosted: Mon Nov 22, 2004 11:37 pm    Post subject: Reply with quote
From what I see happening it's clearly an electrical thing, but where?
D Hook
PostPosted: Mon Nov 22, 2004 11:51 pm    Post subject: Reply with quote
The switches are known to get hot and melt the connections on the back and lose or cross a connection. I'd check there first. I'm sure someone has a replacement on the board they would sell you. IIRC, early 944 switches will work, too. That's what I have in mine right now.
dpw928
PostPosted: Tue Nov 23, 2004 11:47 am    Post subject: Reply with quote
Same thing happened in my 78 928 two weeks ago. Replaced the relay and the problem went away. Upon examination of the old relay I discovered that one of the contacts were burnt. Might try removing the relay cover and cleaning both the upper and lower contacts on the spring.
Dennis
81 931 5 sp
78 928 5 sp Silver
78 928 AT Euro Black
jebe
PostPosted: Fri Dec 03, 2004 1:58 am    Post subject: solution Reply with quote
found it! A loose wire contact at the back of the big contactblock on the headlight switch inside the car (a bit of a snake act) caused the headlights to constantly flip
