Hugo
Joined: 11 Jun 2003 Posts: 73 Location: Uden, the Netherlands
Posted: Thu Jan 13, 2005 7:48 am Post subject: TPS sensor, |
| I'm working on the megasquirt conversion. With installing the tps sensor, i installed a 944 sensor, wich i was told was variabel. well i know now that its not. MS was not very happy with this sensor, fumbled up all the sensor data. Does anybody know if there is a variabel sensor wich has the same size hole for the connecting rod to go into? Gm part maybe? |
Darin81T
Posted: Thu Jan 13, 2005 9:57 am Post subject: |
I used a TPS from a Nissan. It took the same size shaft, but had different spacing on the attachment holes. To remedy this, I simply cut the mounting plate from my porsche TPS and bolted it to the mounting plate on the Nissan TPS, then bolted that hole assembly to the throttle body.
I also pulled the TPS from a junked BMW and it took the same size shaft as well, but it wasn't variable. So if you can find any Bosch or Nissan TPS it should work. Try hitting up the junkyard and bring a multimeter to check that its a potentiometer type TPS.
Later,
Darin Flynn |
Kenodog
Posted: Thu Jan 13, 2005 11:30 am Post subject: |
The guys in Aus say that you can use one from an '80's Nissan Pulsar. _________________ 1979 Euro 931, Olive
1981 931, Sabine
1996 Ford E-350 ex-FedEx Van
2014 Mazda CX-5 (Kinderwagon)
2019 KTM 790 Adventure
2024 KLX300
2024 KLX140 |
Hugo
Posted: Fri Jan 14, 2005 8:02 am Post subject: |
| I believe that a pulsar is called a nissan sunny in europe, do you know what engine? |
