augidog
Posted: Wed Dec 15, 2004 9:48 am Post subject: can I swap 924 old with 944 control arms |
Are old metal 924 control arms swappable with the newer aluminum 944?
Its a 78 924 na _________________ 1978 924 95 mile daily driver.
Vince Ponz
Posted: Wed Dec 15, 2004 10:13 am Post subject: |
I don't think so. You might be safer with the metal instead of the alum. Alum cracks and to replace the ball joints is expensive. Your current ball joints are about 12 bucks ea.
While you are changing the A arms put in Bug Pack 12 dollar plastic bushings. They give a firmer feel.
If you need two 924 iron A arms let me know. _________________ "Never let them see you sweat"
77.5 924 modified track car
79 931 Euro stock
88 924S SE
87 911 Targa stock |
My924gtc
Posted: Wed Dec 15, 2004 10:19 am Post subject: |
You might also want to throw a bead weld along the seems of the steel A-Arm while you are at it. Both sides. This will make them even stronger. _________________ MJ
'81 924 2.0L T
Sponsor of the "2006 Battle in the Badlands" |
Kenodog
Posted: Fri Dec 17, 2004 4:30 am Post subject: |
Unless you know exactly what kind of steel they are made from I would not weld them.To do it properly you need the right filler rod and info like whether to pre heat before welding or post heat treat in order to get the entire part back to the right temper.All steels have different properties and if they crack and a wheel falls off in a hard,high speed corner your gonna be in trouble. _________________ 1979 Euro 931, Olive
1981 931, Sabine
1996 Ford E-350 ex-FedEx Van
2014 Mazda CX-5 (Kinderwagon)
2019 KTM 790 Adventure
2024 KLX300
2024 KLX140 |
Zuffen
Joined: 31 Jul 2001 Posts: 1427 Location: Owasso, Oklahoma 74055
Posted: Fri Dec 17, 2004 6:34 am Post subject: |
7018 rod 1/8 to 3/32 no bigger due to the heat
wire brush the seam and clean out the paint
Just watch your heat and have fun.
The factory 933 arms were gusseted for strength. _________________ Bob Dodd - 924turbo@cox.net
931 1982, 944 1982 euro, 924S 1988SE, 93 968 tip 06 Silver Cayenne S, 06 Black Cayenne S
I have Way too many cars, parts for the 931,944 and 951 |
My924gtc
Posted: Fri Dec 17, 2004 7:27 am Post subject: |
Once again Bob eliminates the guess work.
What a resource you are Mr. Zuffen. _________________ MJ
'81 924 2.0L T
Kenodog
Posted: Sat Dec 25, 2004 6:38 am Post subject: |
Any idea where they put the gussets? A pic would be nice if you've got one. _________________ 1979 Euro 931, Olive
1981 931, Sabine
2024 KLX300
2024 KLX140 |
CBass
Posted: Thu Dec 30, 2004 7:32 am Post subject: |
Nothing quite like a 3/32 7018 rod
MIG would work just fine as well, but I've always preferred the feel of an arc welder over wire feed.
There's a trailing arm, no pics of the A arms. It's not that difficult to see where it would be able to flex, just imagine which direction the forces are going to be exerted on it and weld some sheet metal on where it looks like it could flex. _________________ '81 931 in various states of assembly |
