Too rich ??
PostPosted: Mon Jan 03, 2005 11:59 am    Post subject: Too rich ?? Reply with quote
Im not planning on going to the anilizer wazoo sniffer and spend money.
So I have a question my old mechy let me use his machine awhile back and told me where its best to set the co at as a percentage and total.
I casnt remember what the numbers where if anyone knows tell me.
Though that isnt inportant since Im not goin with the Wazoo sniffer.
So I can go from lean to rich in about one full turn a little less each way.
Then find a spot somewhere in between... MY QUESTION is
wheres best for performance coming from lean do I just rich it up till
the idle stops improving then back it off a little. Theres a spot where it
runs best and if I keep richening the mix idle speeds up a little .Wheres
the optinum spot that some of you guys run at when you adjust the mix by earand feel. I find a little lean from the peak of richening is OK.
