interesting link, hiome made leakdown tester.
924guy
PostPosted: Sun Jan 02, 2005 12:34 am    Post subject: interesting link, hiome made leakdown tester. Reply with quote
found this , anyone do anything similiar? i was looking to buy one, but if this looks like itll work (and the range is okay) it might be worth a shot , and probably allot less expensive...
http://www.650motorcycles.com/LeakDownTester.html
Eric
78 924
82 931 SE "smokey"
99' VehiCross
Y2K Honda Insight
Performance by Pasha
PostPosted: Sun Jan 02, 2005 1:35 am    Post subject: Reply with quote
Absolutely makes perfect sense. You can even just pressurize the cylinder and listed for the leaks as described; if you don't need to quantify them, that'll save you even more.
Hmmm, I've got a regulator sitting in my toolbox... maybe I should pick up a gauge and fittings, get this all rigged up...
PostPosted: Sun Jan 02, 2005 1:37 am    Post subject: Reply with quote
Oh, yeah, also... I bought the fittings that go in the spark plug hole to hold the valves up. This can be used for the leakdown fitting as well, and is cheaper than the SnapOn or such hoses and compression testers...
I find leakdown so much more informative than the compression tester...
PostPosted: Sun Jan 02, 2005 11:40 am    Post subject: Reply with quote
I just bought a leakage tester for less than $70 works great.
3 928s,
PostPosted: Sun Jan 02, 2005 1:57 pm    Post subject: Reply with quote
Im gonna make one of them. Thought I might be headed down
that road 2 weeks ago.
