vollme
Joined: 09 Dec 2004 Posts: 8 Location: Augusta, Michigan
Posted: Thu Jan 06, 2005 4:14 am Post subject: Automatic shifter bezel removal in 924s |
Anyone ever remove the automatic shift bezel from a later 924? If so, how do you do it? Checked out Clarks Garage but nothing on there. Could not see how to remove the knob and the bezel will not come off without removing it.
Posted: Thu Jan 06, 2005 9:42 am Post subject: |
Not sure if I'm referring to the same piece you are, but the process is to detach the leather shift boot from the bezel, and then turn it wrong-side-out over the knob. There should be a clip (or in my case, a very stiff rubber band that replaced the original and now-missing clip) that holds the knob on. Undo the clip or band, remove the knob and shift boot together.
In order to remove the bezel itself, you might need to actually remove the center console, which is covered here (http://www.924.org/techsection/12body.htm#3%20-%20Dashboard%20-%20removal%20and%20installation. I never need to remove the bezel, so that's as far as I can take you. Hope it helps. _________________ erstwhile owner of just about every 924 variant ever made |
vollme
Posted: Thu Jan 06, 2005 12:34 pm Post subject: |
| I wasn't specific enough I guess, I am referring to an automatic shifter. Any ideas? |
