Overheating & Battery Light on
tj924
PostPosted: Fri Jan 28, 2005 12:23 pm    Post subject: Overheating & Battery Light on Reply with quote
Drove the toofah to work this morning (first time in a while) & all was going sweet when the battery light suddenly came on & the temp suddenly shot up well into the red. Slowed to 60kph & the temp dropped below the red but the battery light stayed on. Drive slowly the rest of the way to work & put her in the car park. 1/2 hour later (had a meeting I needed to get to urgently) I confirmed the temp was back down to < 1/2 (as you would expect).
Haven't looked under the hood yet so don't know if something broke or what. Would breaking an alternator belt cause these symptoms? Can someone confirm the water pump uses the same belt as the alternator?
Won't get a chance to pop the hood until after work.
TIA...
TJ
Neil924
PostPosted: Fri Jan 28, 2005 12:25 pm    Post subject: Reply with quote
Could it be wiring? The fan could have stopped working causing the temp spike. Did these two things happen at the very same time? Ground wires perhaps?
tj924
PostPosted: Fri Jan 28, 2005 12:31 pm    Post subject: Reply with quote
Happened at the same time, or VERY close to. Noticed the battery light & checked the temp, which was still OK. A minute or so later the temp was in the red.
Does the alternator belt also drive the water pump?
TJ
Neil924
PostPosted: Fri Jan 28, 2005 12:46 pm    Post subject: Reply with quote
Search: alternator and water pump and belt
http://www.924board.org/search.php?mode=results
click open a few threads and have a look.
tj924
PostPosted: Fri Jan 28, 2005 1:29 pm    Post subject: Reply with quote
Neil924 wrote:
No, I checked and the Alt belt doesn't operate the water pump.
Actually the thread here indicates that the alternator does share a belt with the water pump.
TJ
tj924
PostPosted: Fri Jan 28, 2005 1:43 pm    Post subject: Reply with quote
The alternator/waterpump belt question was a pretty dumb one since I've asked the same thing before & had it answered here. In that post Smoothie said
Quote:
...there's a 10mm belt in the other groove that wraps around the water pump and alternator pullies.
DOH!!!!
TJ
crunchie 57
PostPosted: Fri Jan 28, 2005 2:01 pm    Post subject: Reply with quote
tj
the chanses are you have either thrown the belt off, or the alt has come loose ( check brackets for cracks) as the alt acts as the tensioner for both
78 924 N/A with 944 body kit (love this car)
79 924 NA - track car
81 924 Auto with 6V Buick
macBdog
PostPosted: Fri Jan 28, 2005 2:03 pm    Post subject: Reply with quote
Yep the alt and water pump definitly share a belt. The water will also still flow around by convection but alot more slowly.
1979 931 with a 350 chev
1973 911E with EFI
p-talk wrote:
crunchie 57
PostPosted: Fri Jan 28, 2005 2:04 pm    Post subject: Reply with quote
PS tj
check out Pauls thread " rent a porsche in Brisbane" are you interested in comming on the run ???
tj924
PostPosted: Fri Jan 28, 2005 2:06 pm    Post subject: Reply with quote
crunchie 57 wrote:
the chances are you have either thrown the belt off, or the alt has come loose as the alt acts as the tensioner for both
Thats what I'm expecting too given the symptoms of battery light (alternator stopped) & overheating (water pump stopped).
I'll check it out this arvo anyway
TJ
tj924
PostPosted: Fri Jan 28, 2005 5:46 pm    Post subject: Reply with quote
Just checked the car & the alternator belt is missing (brand new one put on by the local car club guy only a week or so ago as the old one was worn & stretched to the point it could no longer be adjusted).
More concerning is that there is no fluid left in the coolant tank & it was full last weekend when I checked it. First time it's gone through any coolant since I drained & replaced it.
Any suggestions?
TJ
tj924
PostPosted: Fri Jan 28, 2005 6:45 pm    Post subject: Reply with quote
All fixed! The car club guy whacked on another belt, added some distilled water, bled the coolant system (ie ran it until the bleeder nozzle started bubbling coolant) & she's sweet.
Changed the oil in November & both this guy & the last commented specifically on how clean the oil is. Haven't done many km's since the oil change, but I gather very clean oil must be a good sign.
TJ
macBdog
PostPosted: Fri Jan 28, 2005 7:19 pm    Post subject: Reply with quote
Glad its all fixed, musta been scary to watch that temp needle sore(sp) into the red. I wonder where all the coolant went.... and the belt...
Maybe the car club dude didnt put enough tension on the belt when fastening down the alternator and the belt jumped off. Could the belt actually come off without breaking? On my car there is a bracket on the oil cooler lines and the radiator expansion tank line that is bolted to the engine block. The belt goes around this bolt so even if the belt jumped off, it would still be stuck in the engine bay.
1973 911E with EFI
Neil924
PostPosted: Fri Jan 28, 2005 7:46 pm    Post subject: Reply with quote
Good news! I'm glad the car is running well again.
tj924
PostPosted: Sat Jan 29, 2005 8:36 am    Post subject: Reply with quote
Scared the crap out of me!
RACQ guy said it would have boiled over (water pump not running) & spurted out the overflow tank.
That was my initial though too, but I'd re-tensioned the belt last weekend as it was squeeling again, as is expected with a new belt as it stretches.
macBdog wrote:
Could the belt actually come off without breaking?.
I can't see anything on my NA that would prevent it from coming off totally. I also made the dumb-ass mistake of driving at 100+kph for about 5 minutes or so with a very wobbly wheel on the back (expecting new ones from My924GTC any time now, was cheaper to import 'em than to buy 'em in Aus). The car shook like crazy which is what I think probably threw the belt.
TJ
