Interesting find...
tj924
PostPosted: Sat Jan 29, 2005 9:00 am    Post subject: Interesting find... Reply with quote
Noticed the tyre pressure sticker on the inside of my fuel filler door the other day when I was filling the tank. The only size mentioned on the sticker is 15". Does that mean my car originally came with 15: rims? When I got it it had (& still has) 14", after-market 4-bolt rims.
There is also an additional key hole next to the door which I'm lead to believe may be a stock alarm or imobiliser. The PO didn't know & of course I have no key for it so it is useless, but interesting to know.
TJ
Neil924
PostPosted: Sat Jan 29, 2005 9:21 am    Post subject: Reply with quote
I'm pretty sure the 82 came with 15 as stock. The 14 inch wheels were probably picked up by a PO. If your car had an alarm installed at the factory it would have a keyhole behind the divers door.
tj924
PostPosted: Sat Jan 29, 2005 11:08 am    Post subject: Reply with quote
The only genuine 15" 4-bolt rims I know of are Spider Webs & if that's the case (ie it originally came with 15" Spiders), then I think I'll cry!
Thats exactly where it is. I'll post a pic later.
TJ
My924gtc
PostPosted: Sat Jan 29, 2005 11:42 am    Post subject: Reply with quote
Tony, since we have identicle cars, paint, options, and all I am willing to bet that you did indeed have 15" Spiderwebs. By 1982 almost all cars were coming with the optioned wheels, if not with the 5 lug suspension.
Sorry to hear that the PO may have been a ding-a-ling.
MJ
'81 924 2.0L T
Sponsor of the "2006 Battle in the Badlands"
tj924
PostPosted: Sat Jan 29, 2005 12:14 pm    Post subject: Reply with quote
My924gtc wrote:
...I am willing to bet that you did indeed have 15" Spiderwebs.
...Shaking fist at sky...
DAMN YOU!!!
That would have been real nice!
Pretty sure the PO (the 2nd owner, I'm the 3rd) even knew. He certainly didn't know what the 2nd lock near the drivers door was.
Here is a pic of what I think is probably the factory immobiliser lock
Sticker on the window above that lock says "Protected by Auto Pulse"
TJ
My924gtc
PostPosted: Sat Jan 29, 2005 12:29 pm    Post subject: Reply with quote
Have the locks re-keyed to match. A good locksmith can do all 4 exterior locks the same for you and then you can utilize the alarm.
Matter of fact there are some articles over on the Pelican Tech Forums that give you the procedure for re-keying the door locks. If you ever decide you want to use the added feature but don't want to pay a locksmith.
MJ
'81 924 2.0L T
Neil924
PostPosted: Sat Jan 29, 2005 1:18 pm    Post subject: Reply with quote
That's different! Would the alarm still work? Even if you replaced the wires, couldn't the alarm malfunction and not switch off? Would that kill the ignition? Where is the actual alarm located?
Mikri184
PostPosted: Sat Jan 29, 2005 1:58 pm    Post subject: Reply with quote
Be careful with the factory alarm, if they go hay wire, they can kill your alt. as they shut that down, doing the imobolizing. That is what happened to my 944. Now i have a short to my fuel pump, which is related.
Also some 924's in 80 had the 4 lug still as the 5 lug was an option, i have an 82 that came that way.
Life is to short to be looking for something?
Neil924
PostPosted: Sun Jan 30, 2005 12:09 am    Post subject: Reply with quote
That was my fear.
He has an '82.
tj924
PostPosted: Sun Jan 30, 2005 12:39 am    Post subject: Reply with quote
My '82 has 4-bolt. I understood the standard for the NAs was 4-bolt & to get 5-bolt (ie 4 wheel disc) from the factory was an option (M471 or something?).
TJ
