tj924
Joined: 15 Jul 2004 Posts: 957 Location: Toowoomba, Queensland, Australia
Posted: Mon Mar 07, 2005 1:39 pm Post subject: Clutch problem? |
Had one of the back wheels up off the ground when I started the car yesterday. It was definitely out of gear but the wheel was spinning. Pulling on the hand-brake stopped it easily but it was too fast to stop it by hand easily.
Could this indicate a clutch problem or something? _________________ TJ
Silver '82 924 NA 5-Speed Manual |
Posted: Mon Mar 07, 2005 11:43 pm Post subject: |
if you can put your foot on your clutch and get your car into reverse, your clutch is fine,
mostly that will be due to just abit of friction in the oil/parts in the tranny and imo is normal _________________ 3 928s, |
tj924
Posted: Tue Mar 08, 2005 10:56 am Post subject: |
| Lizard wrote: | | if you can put your foot on your clutch and get your car into reverse, your clutch is fine, mostly that will be due to just abit of friction in the oil/parts in the tranny and imo is normal |
Woohoo! Thank god for that! Shifts easily in all gears, no crunching or anything. _________________ TJ
924zombie
Posted: Tue Mar 08, 2005 11:41 am Post subject: |
Tis normal dude,it`s when you have both driven wheels up and they`re turning in opposite directions that really freaks people out  |
Posted: Tue Mar 08, 2005 3:34 pm Post subject: |
You know what else if you keep lifting it off the ground using a common 2 ton jack youll finally rig up something to fit into the jack points. I have. _________________ 1979 porsche 924 Na
Have u ever driven a turbo. |
