rotor button
maireeka
PostPosted: Mon Mar 07, 2005 8:30 am    Post subject: rotor button Reply with quote
I've never really worked on an ignition system, and I don't know how to get the rotor button out so I can replace it with my new one. I just put the new cap on last night and I'm hoping someone can explain to me how I get the old rotor out. I tried pulling and it wouldn't budge and I didn't want to break anything.
How do you remove the rotor button?
Patrick
1977 Porsche 924 red and READY!
PostPosted: Mon Mar 07, 2005 8:33 am    Post subject: Reply with quote
the rotor arm (or piece that spins inside the cap), just slides off, sometims they are abit sticky but on the 924 2.0L they just pop off, pull harder,
3 928s,
maireeka
PostPosted: Mon Mar 07, 2005 10:43 am    Post subject: Reply with quote
got it. thanks for the help, I thought it would pull out, but I was afraid I'd bust something up and I didn't want to have to buy a new distributor.
sleepy
PostPosted: Tue Mar 08, 2005 1:30 am    Post subject: Reply with quote
how do you know when the rotor arm need replacing? I looked at mine the other day & the contacts look quite worn, - gone a blue grey colour (on the arm & the distributor cap). I don't know if it's ok to give them a clean with a wire brush or something?
meteor silver 1981 924 lux. -UK
maireeka
PostPosted: Tue Mar 08, 2005 1:51 am    Post subject: Reply with quote
Mine probably looked a lot like yours, I went ahead and changed it because it was one of the only cheap 924 parts available at any of the local auto parts stores. After changing the cap and rotor, there was a very noticeable change in the quality of the idle. The only other thing I have that needs replacing is the plug wires.
